mattsmadmini wrote:
Hey ya'll sorry for the thread reso.... I've noticed my speedo is doing the same thing... but from 0-100kms bouncing all over the place... ive got a new speedo cable and its still doin it...
anyone suggest a good friendly instrument reconditioner around sydney?
CHeers,
Matt
If the needle flicks when the car is moving very slowly, and it's not the speedo cable at fault....and if you are adventurous, you can take the speedo apart and resolve the issue yourself.
inside the speedo, the speedo cable connects to a drive shaft which connects to a magnetised disc. When the car is moving this magnetised disc spins inside a large shallow cup. This disc as it spins induces a movement in the cup. The cup is connected to the speedo needle and will deflect the needle proportional to the speed of the disc.
Over time, the disc moves a forward by a tiny amount. This is caused I deduce by the odometer mechanism becoming a little gummed up. This in turn applies pressure onto the gear mechanism which in turn alters the gear alignment on the speedo drive shaft. This moves the disc deeper into the cup where it starts to touch a little, once per rotation of the disc, enough to cause the needle to flick at slow speeds. Once the car speeds up a little, the flicks even out and simply make the speedo inaccurate.
Sounds tricky, but is easier to see once it is apart.
All it takes is to slide the odometer drive gear a little along the shaft a little to pull the spinning disc back enough to stop the contact. This fixes the issue.
