It is currently Wed Jul 30, 2025 12:38 pm
 Post subject: Length?
PostPosted: Fri Feb 20, 2009 4:17 pm
I'm at work and they have tightened up the internet access even more - can't see pictures (they take up band width :roll: ) and the seach function will not work - I'm lucky to even post - takes me several goes.
All I want to know is the length of the threaded rod for a DIY cone compressor
David L
PostPosted: Fri Feb 20, 2009 4:32 pm
Tomboss Breweros
30 cm should be ample, withspare to cut off it the thread gets mashed.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Feb 20, 2009 6:11 pm
You want good high tensile threaded rod and Grade 8 nuts, there are tons of force on this thing when done up.
Put a plate on the crossmember or you will collapse it into the hole, there is no strength below it on these early subbies.
Users browsing this forum: Hobson and 89 guests
