It is currently Sun Jul 20, 2025 2:02 pm
 Post subject: which fan
PostPosted: Sun Feb 20, 2005 10:34 pm
which fan will cool the best ? I have a 16 blade metal one and a 12 blade plastic one. HoweverI was looking under the bonnet of a racing cooper s at the weekend and saw it used a 2 blade metal one please help ?
1977 Clubman
PostPosted: Sun Feb 20, 2005 11:09 pm
The 2 blade fan is basically half of a 4 blade fan. The reason for only using 2 of the blades is that the racing mini is mostly driven at high speeds. At high speeds, a 2 blade fan allows more air to pass thru the radiator as it is forced thru the grill. When stopped, this racing mini will overheat easier.
If the racing mini was to use a 16 or 12 blade fan, the air would actually be blocked by the blades at racing speeds, essentialy making the engine run hotter.
If you do alot of city/slow driving/peak hour crawls, the 12 or 16 blade fan is your best bet. On country roads at high speed, especially in summer, a 4 blade fan is better.
A mini's fan only uses up about 3/4 of a horsepower, so less blades wont really affect the power.
I hope you can understand this, I cant think of a better way to describe it....
PostPosted: Sun Feb 20, 2005 11:41 pm
So metal or plastic then as i have both
1977 Clubman
PostPosted: Mon Feb 21, 2005 7:26 am
I think the accepted dogma is that the multi blade plastic one is better shaped allowing better airflow to the radiator
PostPosted: Mon Feb 21, 2005 7:36 am
But, the plastic one IS noiser than the 16 bladed metal one. Plastic ones also do fling blades off.
Whatever.. I run one of each... 8)
PostPosted: Mon Feb 21, 2005 11:39 am
no fan - yay!!! get an electric one ;)
PostPosted: Mon Feb 21, 2005 12:23 pm
I would use the Tropical fan that was availavle on export minis to hot climates.
Don't use the white plastic fan. These are the ones that have a tendancy to explode.
If you only have the yellow 16 blade fan or the yellow plastic I'd use the plastic.
PostPosted: Mon Feb 21, 2005 1:09 pm
Yeap I have a Plastic one on mine and now troubles.
I have seen the 4 Blade Rally type fan crack and go through the rad.
Nasty surprise when you have to do a rad and a fan.
I've Got One
You've Got One
We've All Got One
What Is It
A Bloody Mini
Users browsing this forum: No registered users and 70 guests
