It is currently Sun Jul 20, 2025 1:38 pm
 Post subject: Brake Help.
PostPosted: Mon Feb 21, 2005 7:18 pm
I was getting a noise from one of the front wheels and when I checked it out I found the hub nut loose.I tighten and went to take it for a test drive around the block .Hit the brakes and nothing, luckily the hand brake worked.
Now if I pump the brakes they come up but as soon as I release the pressure they're gone again.I tried bleeding, the brake cyclinders and hoses were new 6 months ago,a new kit put in the MC about 12 months ago and I can't see any leaks.
Coincidence or did I accidentally do something when I tightened the nut.
PostPosted: Mon Feb 21, 2005 7:32 pm
do you have discs or drums??? did you check the brake lines? may have cracked or split a line from the loose nut.
1974 Moke - 998cc
PostPosted: Mon Feb 21, 2005 7:43 pm
Drums.The brake lines do look ok but I will check again tomorrow.
Users browsing this forum: No registered users and 66 guests
