It is currently Fri Jul 18, 2025 7:17 am
PostPosted: Mon Mar 16, 2009 10:28 pm
I'm Bert , where's Ernie
need to get at bolts holding the big ends in, theyre turned just far enough down that i cant get a socket to them, just wondering how i go about turning the crankshaft (no sump on it, no head, stripping it out) to be able to get at them. Already removed the caps.
also the crackshaft pulley bolt, how in hell do i move that, had a shifter and a hammer trying to go at it, couldnt make it budge
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Mon Mar 16, 2009 10:29 pm
is it upside down?
blokeinamoke wrote:
PostPosted: Mon Mar 16, 2009 10:31 pm
you probly should have undid the front crank bolt a bit before you pulled it to bits.
If you have undone the bearing caps just pull the crank out of the block a bit buy tapping the pistons down into the bores.
blokeinamoke wrote:
PostPosted: Mon Mar 16, 2009 10:39 pm
yep, sure is flipped.
yeah, bearing caps are out, cept the one closest to the fan, thats pretty stuck, didnt wanna try and force it if i needed to take the bolt out before hand, theres some rubber between it and the side of the block, this being my first ever rebuild, didnt wanna force anything unless i need that part later on haha.
PostPosted: Mon Mar 16, 2009 10:53 pm
Tomboss Breweros
To turn the crank, get a big screwdriver and put the tip of it across the slot in the clutch end of the crank, it should move easily.
To get the front bearing cap (the one with the rubber seal over it) using the big screwdriver again to apply some force to the crank away from the block, once it starts to move ease off and some gentle hammer application and pulling by hand should get it. Probably just sticky on the dowells.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Tue Mar 17, 2009 9:31 am
ditto...
I tend to gently tap the side of the caps before trying to lever them up, a few light taps on each side and they usually lift up, then flick the rest of the way with a screwdriver
Drifter - don't remove the rod bolts from the rods unless you plan to replace them with newies - you're best off leaving them in the hole they're used to, and you don't risk damaging their threads
PostPosted: Tue Mar 17, 2009 9:38 am
do yourself a favour and go buy a 1 5/16" socket - you'll need it anyway, and buy a 1 1/2" socket too.
You should be able to undo the pulley nut with a helper holding a screwdriver across the tail of the crank - it's torqued to 70lb/ft, so isn't super tight, but definitely not loose
If you can't undo it that way, put the flywheel housing back on the motor (it's 4 bolts - get over it) and sit the flywheel back on with the flywheel bolt finger tight. Get one of your old main bearings and use it to lock the flywheel from turning - put the bearing between some teeth, through the starter motor hole
keep a couple of your old main bearings for the same purpose - they're the best flywheel locking tool you can get for free ;)
PostPosted: Tue Mar 17, 2009 9:59 am
To stop the rotation of the crank all you need to do is put a block of wood down between the side of the block and the web of the crank. A decent sized hammer handle usually does the trick. Then just turn the crank until it touches the wood and it will stop it turning.
I agree the big sockets are worth buying. Don't use them very often but when you need them they save you a lot of time spent cursing and swearing.
Pete
PostPosted: Tue Mar 17, 2009 10:01 am
that's a better idea! :lol:
PostPosted: Tue Mar 17, 2009 10:12 am
This space for rent
There is no substitute for having the correct tool for the job.. makes even the difficult jobs a pleasure 8)
PostPosted: Tue Mar 17, 2009 10:55 am
Sounds like you stole my mates tool kit :lol:
DOZ
PostPosted: Tue Mar 17, 2009 3:50 pm
well, after todays efforts, ive ended up with a smashed pinky (yes i hit it with the hammer) and ive snapped two of my screwdrivers, and still havent progressed, the last big end is still stuck, and the crackshaft pulley bolt is still on there, will give it another go maybe on friday after i can find some more screwdrivers.
by the way simon, when i bought it, it had no gearbox, or clutch or flywheel etc etc. Which slot were you guys talking about on the end of the crank? the big one on the very end with the hole in the middle of it? Where do you find screwdrivers that big?!
PostPosted: Tue Mar 17, 2009 4:46 pm
:lol: :lol: :lol: :lol:
gotta laugh or else i'll cry, dont ask me how i did it, but i smacked my big toe, i think it was in the order of
get correct size socket,
put it on and attach breaker bar,
strain until i realise im too bloody weak,
break out the hammer again
smack breaker bar with the hammer,
realise too late that the hammer bounced off the bar and hit me in the foot,
THEN, to make it all worse,
the socket fell off when i let it go and it smacked me in the same foot, in the same place,
just went and sat down in the corner and had a giggle with a can of coke.
PostPosted: Tue Mar 17, 2009 4:56 pm
Its in the workshop manual!!!
PostPosted: Tue Mar 17, 2009 4:58 pm
ginger ninja
ginger ninja
ahhh Robbie, you are like a miniature BIAM :lol: :lol:
sports850 wrote:
