It is currently Sun Jul 20, 2025 1:17 pm
Post new topic Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Tue Feb 22, 2005 9:24 pm
It is far worse when your mini makes no noise at all. What so ever. :D
PostPosted: Tue Feb 22, 2005 9:41 pm
Pops goes "brooom brooom biddy brooom biddy brooom brooom brooom" and JAM goes " "
:lol:
Actually Pops has a few clunks from the front when I hit bumps in the road.... :?
PostPosted: Tue Feb 22, 2005 9:59 pm
the worst noise my mini makes is the *CHING CHING* at the cash register when i have to get it fixed. :cry:
PostPosted: Tue Feb 22, 2005 10:23 pm
mine purrrs like a pussy cat 8)
PostPosted: Tue Feb 22, 2005 10:26 pm
I can't comment to much..I only drove it up the driveway and then I had to push it up half of that.
Then thier is Morris :oops: I listen for everything...Wify..she just turns the vibes up :?
PostPosted: Tue Feb 22, 2005 10:57 pm
mine hasnt made any noises yet ::(:(:(:(:(:(
PostPosted: Wed Feb 23, 2005 12:48 am
Worst noise = the "ZZZZZZZZZZZZZZZZ" metal makes when an angle grinder does its business. Cos you KNOW there's NO turning back Image
PostPosted: Wed Feb 23, 2005 8:25 am
mine is a rattle that the little bars in the doors that go from the handle to the actual locking mechanism make as the vibrate away!! oh mine is a clubbie, i dont know if roundies have these bars, excuse my ignorance!!! :lol:
PostPosted: Wed Feb 23, 2005 8:33 am
yea clubby only for them. there is supposed to be foam between them and the door...to stop that. Yea yea...I didn't put any there either when I did JAM's doors..... :?
PostPosted: Wed Feb 23, 2005 8:51 am
I have the same noise too depending on idle rpm :evil: Sometimes I get pissed off and whack the door card which usually stops it :mrgreen: :roll:
PostPosted: Wed Feb 23, 2005 9:06 am
The worst noise mine made was either
1 the squeeky grindy noise where the front left knuckle joint had failed and was grinding into the upper suspension arm
or
2 the shuddering groan from when I put discs on and didn't bed them in properly.... :oops:
3 the noise the new duplex timing chain made as the chain ground slowly but surely into the timing cover :( (the old duplex setup had fit, didn't think the replacement was much different, I was wrong...
Oh, and all of the clunking noises due to destroyed engine mounts....
But she's all quiet now!
Matt
PostPosted: Wed Feb 23, 2005 9:11 am
The crunch as my sump guard collects the bumps in the crappy roads we had around Armidale.
That's why it has the sump guard :wink: and I guess it is not doing any real damage but it still sounds awful and the though of any part of the mini coping a belting is not nice :evil:
Roads need more corners
PostPosted: Wed Feb 23, 2005 9:53 am
I have a rattle at idle caused by the vibration of the fire extinguisher mounting bracket. I either just put my foot against it or rev the car!!
Bob Slattery
PostPosted: Wed Feb 23, 2005 9:55 am
High heel ninja
My grunter has the heaven & hell syndrome, the whine from the straight cut gearbox, its annoying, but fantastic at the same time.
Doogie
PostPosted: Wed Feb 23, 2005 9:56 am
Speaking of Grunter, have you made any progress on the sale yet??
Bob Slattery
