It is currently Sun Jul 20, 2025 1:48 pm
 Post subject: Water Pump
PostPosted: Wed Feb 23, 2005 11:22 am
Could someone tell me if this a standard water pump or not.
The impellor is 52mm wide and 20mm deep.
The only numbers on it are 17.331.2, 17.244.8 and 13j020.
Any help would be great.
Cheers Pete
PostPosted: Wed Feb 23, 2005 11:35 am
looks like a standard late model pump, i rather the cast impellor types as the pressed ones rust off alot quicker and float around in the cooling system. edit: i crossreferenced all the numbers on the karcraft catalogue, none matched up , here are their p/n
GWP134 <A> WATER PUMP - MINI (HI CAPACITY)
GWP132 <B> WATER PUMP - MINI (SMALL IMPELLOR)
lookin for another clubby
PostPosted: Wed Feb 23, 2005 3:27 pm
i thought that was the high flow type?
rather than the standard which is basically a star.
inevitably im probably wrong :wink:
PostPosted: Wed Feb 23, 2005 3:35 pm
looks to be the same as the one that came out of my thrash motor :?
looked like a hi-flo one,but when i asked my boss,he just said it was a poofter one,so my guess is its late model one(seen a fue like that one come off rovers)
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Wed Feb 23, 2005 9:00 pm
That's got to be bad for it!!! :cry:
Users browsing this forum: No registered users and 69 guests
