It is currently Sun Jul 20, 2025 8:44 am
 Post subject: Is that noise normal?
PostPosted: Sat Apr 04, 2009 3:30 pm
When I drive the mini around, commonly in third or fourth gear and I tap the accelerator on/off quickly there is a noticable thud sound.
I thought the engine stabilisers were worn, so fitted new ones, and I even put in a third stabiliser altogether.
The noise still exists but isnt as loud. Do all minis do this or have I missed something else?
PostPosted: Sat Apr 04, 2009 5:00 pm
Is it a 1275?
It could be the harmonic balancer rubber worn if it is a 1275. That can also give you an audible knock on idle.
PostPosted: Sat Apr 04, 2009 6:20 pm
Also if it is a Rover check the sub-frame mounts.
Cheers Pete
PostPosted: Sat Apr 04, 2009 9:45 pm
Engine is an 1100 unit. Haven't checked the subframe mounts, will do tomorrow.
:D
Users browsing this forum: Bing [Bot] and 83 guests
