It is currently Mon Jul 21, 2025 2:28 am
 Post subject: painting the grill
PostPosted: Thu Feb 24, 2005 5:44 pm
I was wondering if i needed to paint a grill white, would i have to prime it and then what type of paint would i need? and or what other processes would i need to do?
PostPosted: Thu Feb 24, 2005 8:54 pm
I reckon you'd have to rough up the stainless pretty well so the paint would stick, get it really clean and use a good etch primer
some clubby grilles were black as standard weren't they?
PostPosted: Thu Feb 24, 2005 11:04 pm
hhmmm ok, i'll do some more research........
PostPosted: Fri Feb 25, 2005 8:03 am
Clubby grilles were matt black, with some parts not painted, to give the silver lines effect.
On the 2 grilles I have stripped, the black was applied straight to the metal, with no primer......but when I re do my own, I will use an etch primer then matt black over that.
PostPosted: Fri Feb 25, 2005 2:39 pm
Jam, did you have to prep the surface of the grill before you did it? what method did you use?
Users browsing this forum: Majestic-12 [Bot] and 99 guests
