It is currently Tue Jul 29, 2025 3:42 am
 Post subject: Disc Brakes
PostPosted: Fri Apr 17, 2009 12:11 pm
Hi,
I want to buy some disc brakes for my mini. I want to keep my 10 x 5 superlites, so 8.4 inch discs are out. Im looking at cooper s disc brakes but i found the minisport 7.9 inch 4 pot callipers for not much more. Are these brakes worth getting over the stock discs? The car has a mildly worked 998 and im looking to do a few hillclimbs and autocrosses.
Joe
PostPosted: Fri Apr 17, 2009 12:28 pm
If they are the minisport UK calipers, drop willy a PM to ask about the set he had fitted. He had some problems with poor pedal due to flexing.
PostPosted: Fri Apr 17, 2009 1:42 pm
I just had two friends here in town order 7.9" Vented discs with alloy 4-pots from minisport UK, they both had extremely poor pedal. No matter what they did, it stayed the same. (one is a good mechanic) I suggested they need better brake pads, (they presumed the supplied pads would be a good grade, i said they'd be the cheapest as it was a 'package') They bought some of the 'sports' pads from minisport UK. Instant fix, now they have perfect pedal. :wink:
They both use minis in sprints & hillclimbs etc. They say there is a slight but noticable improvement over there cooper s discs.
Matt
PostPosted: Fri Apr 17, 2009 2:33 pm
I'd be fitting standard Cooper S discs/calipers.
PostPosted: Fri Apr 17, 2009 2:38 pm
I like Cooper S discs and calipers. Parts are easy to get here and relatively cheap.
They stop great on the road with Blackstuff pads even without a booster, ditto on track days etc with Greenstuff pads.
PostPosted: Fri Apr 17, 2009 5:44 pm
Don't need anything more than Cooper S 7.5's mate
Lillee - 1969 Morris Mini K
PostPosted: Fri Apr 17, 2009 8:26 pm
Thanks heaps for the info, think ill go for the stock cooper s discs. That sounds like the best option.
Cheers.
