It is currently Wed Jul 16, 2025 7:49 am
PostPosted: Sat Apr 18, 2009 9:10 am
I have a Mk1 car & getting a Mk2 Cooper S wiring harness.
The wiper for the car at present is single speed & r/h park. It works, connected pin 2 & 3 to a battery.
Looking at the wiring diagrams, both Mk1 & Mk2 have single speed & 3 wires to the wiper motor.
Do they return to the park position when the switch is selected off?
Should I get the wiring for 2 speed wipers added, just in case I put in a 2 speed wiper later?
Are 2 speed wipers better?
Any difference with motor size, shape?
Do they attach to same wiper rods?
1967 Morris Mini Deluxe
1927 Austin 7
PostPosted: Sat Apr 18, 2009 9:17 am
Mk1 and Mk2 wiper motors (sq vs round) have a different rack travel, and different wheelboxes to suit.
Also the motor mounting holes on panel are different.
Yes they do park when turned off.
If you fit a round motor to the old square motor's rack, the wiper arms will swing 180° = too much. Need to swap the wheelboxes too.
Last Mk2s and Police ones had the 2 speed Clubby motor, there is a thread here with the right wiring and switch details.
see http://www.ausmini.com/forums/viewtopic ... peed+wiper
In your case I would add an extra wire, long enough to go from the motor to switch- but leave it disconnected for now.
Here's the wiring in mine now, with 2 speed Clubby motor. Switch is MGB one.
Last edited by drmini in aust on Sun Apr 19, 2009 10:34 am, edited 2 times in total.
PostPosted: Sun Apr 19, 2009 9:49 am
Where can we get these switches Doc, Karcraft?
Dicko
PostPosted: Sun Apr 19, 2009 10:14 am
Heritage MG stocks them.
The toggle on it looks similar to a Mini one, but it has less angular movement between the positions. ie when up (off) it sits a little lower than your headlight switch does.
http://www.mgspareparts.com.au/index.ph ... &Itemid=26
PostPosted: Sun Apr 19, 2009 7:35 pm
does it matter that the mini with the square wiper motor parks on the opposite side?
PostPosted: Sun Apr 19, 2009 7:37 pm
You can make the round motor (1 or 2 speed) park on RH side simply by turning the drive pin plate 180° on the plastic gear.
I tried this and it works. :wink:
If easier for you I can show you how to make the square motor have 2 speeds (or variable speed), PM me for details.
PostPosted: Sun Apr 19, 2009 8:58 pm
i get my car back this week so ill try it out ill let you know
Users browsing this forum: Bing [Bot] and 96 guests
