It is currently Mon Jul 21, 2025 2:26 am
PostPosted: Fri Feb 25, 2005 9:17 am
Hey is it just me or am I missing something? Everytime I click on "New Topic" or "Reply" it brings me back to the front page of the forum?? Do I need to do something or is this a common occurance? :( I had to click on "New Topic at least 4-5 times to post this one...
PostPosted: Fri Feb 25, 2005 9:28 am
use the board from this URL:-
http://www.ausmini.com/forums/index.php
You are using the wrong URL. Change your bookmarks.
There were several topics on this..... :wink:
The reply wouldn't work for me until I made sure I was changed over to the new forum site.
Roads need more corners
PostPosted: Fri Feb 25, 2005 11:32 am
Yep... it's the way the forum is setup. If you go straight to www.ausmini.com/forums/ then you wont have any problems. I worked this out just after I moved the forums over. In the old forums, some were having problems with cookies, and this problem is the same. So if you go to forums.ausmini.com you may have a problem. I updated the links from the front site when I worked out what the problem was.
PostPosted: Fri Feb 25, 2005 11:00 pm
Cheers guys! I knew I was doing something wrong! :wink:
Users browsing this forum: Majestic-12 [Bot] and 99 guests
