It is currently Fri Aug 15, 2025 2:25 pm
 Post subject: the flywheel
PostPosted: Sat Apr 25, 2009 8:21 pm
HI guys does any one know the minimum thicknes a flywheel can be as i would like to grind a little off engine is 1100 if it makes any diferance
CHEERS.
PostPosted: Sat Apr 25, 2009 8:32 pm
big yellow vizard has dimensions of what to take off & where
PostPosted: Sat Apr 25, 2009 8:36 pm
Not in mine (2nd edition), but it's in his other book- How to Modify Your Mini. :wink:
PostPosted: Sat Apr 25, 2009 8:48 pm
I have that book, but do you really want to shave it off.
There are three types of flywheels, and the best one to use is the big solid one piece one. You would think that lightening a flywheel has a benefit, but youll find that the heavier flywheel actually works better.
Get it balanced at an engineers and bobs your auntie your ready to go.
PostPosted: Sat Apr 25, 2009 8:55 pm
Drexxle wrote:
... but youll find that the heavier flywheel actually works better.
Better as in allows your tractor to plough your field more smoothly?
A lightened flywheel makes a big difference to the rate of acceleration.
It really is "cheap horsepower" and should be one of the first items on the list of anyone looking for increased performance from an engine, particularly an A-Series.
PostPosted: Sat Apr 25, 2009 8:59 pm
Tomboss Breweros
I reckon the real problam is that it's stuck to a crankshaft and has a busted thread, I reckon i know someone who might be able to fix it :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sat Apr 25, 2009 9:00 pm
if your racing the thing then yeh fair enough, if its a daily driver then easier gear changes and smoother deceleration. Guess you got to work out the trade off.
PostPosted: Sat Apr 25, 2009 9:09 pm
you're right... it's not in big yellow
My friend lightened my flywheel as per vizard years and years ago, I think it worked out to be 1.3kg lighter than standard. I drive it every day and don't' have a problem with it - I want to go lighter for khanas
PostPosted: Sat Apr 25, 2009 9:23 pm
I did this excersise a while back
At the time I remember calculating the apparent difference in performance is like having or not having a passenger in the car.
David L
PostPosted: Sat Apr 25, 2009 9:27 pm
This space for rent
.. but the rationale is. Lighten the reciprocating masses and the engine 'sees' a lighter car and can accellerate harder.
PostPosted: Sat Apr 25, 2009 9:30 pm
that's what vizard says about it
PostPosted: Sat Apr 25, 2009 10:01 pm
Just buy Aaron and Doogie some Krispy Creme's - It'll work out cheaper.
kB
PostPosted: Sat Apr 25, 2009 10:11 pm
kB
but then I can't have any myself, and that's no good!
PostPosted: Sat Apr 25, 2009 10:13 pm
Tomboss Breweros
He just wants to make it competetive against mine :P
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Apr 26, 2009 10:12 am
completly the tool manufacturers fault for cheeping out and not using high tensile bolts :shock: :shock: :shock:
Users browsing this forum: Bing [Bot] and 285 guests
