It is currently Mon Jul 14, 2025 11:57 pm
 Post subject: help with leads
PostPosted: Tue May 05, 2009 3:18 pm
put new dizzy cap and leads in but i'm unsure about the order before i turn the key.
i took photos of the last cap and leads set up before i took it out but i'm still sketchy on it. at the moment it looks like the firing order is 1234. clearly wrong.
anyone able to get me a photo of where all the leads go from the cap to the sparky plugs?
PostPosted: Tue May 05, 2009 3:21 pm
Based on "Should be"
1 oclock is 1
11o'clock is 3
7oclock is 4
4 oclock is 2
all based on factory setting and factory items
- 1962 Beige Delight club car, Rebuilding.
- Motorkana Special
- Minor Mishap, 1958 Morris Minor
-- Last ever Tea Lady at Longbridge--
PostPosted: Tue May 05, 2009 3:26 pm
you don't need an image, it's 1-3-4-2 usually starting from the 2 o'clock position and going anticlockwise.
If you had you dizzy oriented wron all along, then you will need to rotate the plug sequence to each of the four possibles (but in the same anticlockwise order) until you get it right.
You can also take the rocker cover off, align the engine to number one firing (No 1 piston at or near TDC, both valves closed) and the rotor button will be pointing to the number one position.
PostPosted: Tue May 05, 2009 3:32 pm
Resident Haemorrhoid
1 oclock is 1
11o'clock is 3
7oclock is 4
4 oclock is 2
You still on daylight savings time Mick :lol: :lol: :lol: :lol: :lol:
mtsmini wrote:
Tombo wrote:
PostPosted: Tue May 05, 2009 3:49 pm
Ah well, you will need to adjust this position dependant on where you are in Australia.
-Perth will need to adjust number one to 12 o'clock,
-South Australia adjust number 1 to 1.30
-Queensland will need to adjust distributor by roating anticlockwise (20yrs*365days*24hrs) = 175,000hrs to adjust for their lag in time.
PostPosted: Tue May 05, 2009 3:54 pm
What if you live in Queensland but your engine and timing was set up in NSW :?
David L
PostPosted: Tue May 05, 2009 4:00 pm
You will need to retard the timing as you cross the border.
PostPosted: Tue May 05, 2009 7:03 pm
and th cyclinders are 1234 left to right right?
PostPosted: Tue May 05, 2009 7:20 pm
Number one is closest to the radiator.
PostPosted: Tue May 05, 2009 8:25 pm
:P Its closest to the water pump :!: :lol: :lol: :lol:
PostPosted: Tue May 05, 2009 8:26 pm
no it's closest to the thermostat :P
PostPosted: Tue May 05, 2009 8:27 pm
This space for rent
Oooh, I don't know about that. The pump impellor is pretty close to #1 cylinder wall, closer than the thermostat is..
Users browsing this forum: Bing [Bot] and 91 guests
