It is currently Sat Jul 12, 2025 6:36 pm
Post new topic Reply to topic  [ 50 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Thu Feb 24, 2005 9:28 pm
i think what happend was that it ran off the water pump,but it kept eating its bearings out and became a pain in the arse,so it went off the ballancer with a air con pully to reverse the drive...not sure as i only heard about this from his bro on sunday,the man himself was at the workshop pissing about with his new rover...
i can find out more for you?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Feb 25, 2005 8:40 am
nah, it's OK.... just fishing, I'm not going to do anything with the info, tho these other guys may be curious
PostPosted: Fri Feb 25, 2005 9:42 am
i have a s block, rods, crank, timing gear, cam, and head if u wanna build a 1380
it's a 1310 now i think
PostPosted: Fri Feb 25, 2005 9:46 am
i heard that 1380's arent real great (unless ofset bored) for super and turbo charged engines as the bores can warp slightly with the amount f force put into the chmbers.... :shock:
true? :?:
68matic: "i havent seen much head in my life "
PostPosted: Fri Feb 25, 2005 10:01 am
from what iv been told,the 1380's bore walls flex around under forced induction,so a 1293 or 1310 is your best bet.
boss has a turbo 1440 or something crazy like that,he dont expect it to last very long,
People goto 1380 for more NA power,bigger motor,more fuel/air,big bang,...you go small big strong motor,strap turbo on,and it will force more fuel and air into a smaller motor and get you a eaven bigger bang=more power :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Feb 25, 2005 10:08 am
yeah certainly understand that theory... Higher reving engines also work better with turbos as it keeps em on boost longer.....
cant wait.... any one need a weber?
PostPosted: Fri Feb 25, 2005 10:13 am
PM brickworx,
i think he no's of a fue people wanting weber setups like you have,they sell like hot cakes over here..i can have a word to him about it of you want?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Feb 25, 2005 10:19 am
would appreciate it
PostPosted: Fri Feb 25, 2005 10:39 am
ok ill go speak to him at lunchtime :D
any progress on the turbo set up?im a big fan of your setup coz there is no firewall mods.
did you still need a HIF44 carbie?
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Feb 25, 2005 1:44 pm
i went and saw the guys at midel a couple f hours ago... really nice guys in person.
He wants $250 to convert the HIF44 I have or roughly $500 for a brand new turbo carb... I think I will go for the converson as its cheaper...
progress towards the setup... I got my BOV yesterday and have the fuel pump on order. Blue Holley and comes with regulator...
Question to anyone in the know, will i need a raising pressure regulator for the turbo install???
PostPosted: Fri Feb 25, 2005 3:49 pm
its still a SU,so i would say no,coz to much pressure in a SU will push the needel up and flood the carbie,S's need a healty flow,but that at high pressure,ill say that a holly blue and regulator sound be just fine :D
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Feb 25, 2005 4:27 pm
I belive Kazjim uses a Holley Blue Turbo 998
I have seen (in Pommy mags) where they use the good old HIF44
PostPosted: Fri Feb 25, 2005 7:11 pm
Clubman, Yep, i use the Holley Blue (Noisy Ferking thing.....)
I also use the standard Holley Regulator, BUT I've modified the hell out of it to make it rising rate.....
Sealed the top section (devcon and a couple of "O" Rings..) drilled and tapped the side and fitted an air barb fitting.... ("O" ring there as well ....)
Works pretty good......
Drop me an email if you want some pics....
J
PostPosted: Fri Feb 25, 2005 9:33 pm
noisy aye?> even on the move you notice it....?
noise from my car isnt a problem, its not a daily driver and its driven because I like the lack of refinement (though some cooling for me would be nice especially in this weather) :!:
How much boost you running?
PostPosted: Mon Feb 28, 2005 9:13 am
is the honey blue a EFI pump?
on of the turbo cars at work has some crazy big pump with 3/8 lines,a bit of a waste going to a SU..
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
