It is currently Sat Jun 28, 2025 1:15 am
PostPosted: Wed May 13, 2009 10:55 pm
HI guys,
The mini is back from the paint shop after the touch ups etc and she's lookin sweet. I have done all the small bits and pieces needed to make her tidy but one BIG problem remains!..
THE LOUD EXHAUST!
Its in no way loud as some of the commodores that are flying around but the boys at RTA are sure to fail me as soon as they bring in their sound level meter.
its a 2.5" straight through system.
How can I "temporarily" reduce exhaust tip noise? :twisted:
I've heard people putting in a perforated plate inside with a few tack welds to reduce the effective area.. I did this but not much of an effect!
Maybe I put too many holes! ( I put approx 13 holes of 10mm diameter)
Any suggestions welcome! its gotta be done tomorrow! I've got her booked at noon on Friday
Really don't want to be fitting new mufflers at this stage
Pubs
PostPosted: Wed May 13, 2009 10:58 pm
This space for rent
It'll do bad things for your power delivery (actually considering you're going over the pits, make that "good things" ;) ) -- pack the muffler, extractors or tail pipe with steel wool :idea:
PostPosted: Wed May 13, 2009 11:03 pm
thanks mate.. power delivery is the last thing I am concerned about.. as long as it doesn't shoot out bits of steel wool out the exhaust!
PostPosted: Wed May 13, 2009 11:16 pm
This space for rent
If you weld your perforated plate into the exhaust pipe just downstream of the extractors, then pack the end of the extractors with steel wool it'll stay in place and probably sound heaps quieter ;)
PostPosted: Wed May 13, 2009 11:42 pm
I have already welded a perforated plate inside one of the flange connections so nothing can be seen from the outside.
The RTA guys can easily spot an 'extra' piece of steel between flanges! :D
Time to head to Bunnings and get some steel wool!
I'll pack it upstream of this plate so as you said, so it will hold it in place.
I'm going to be going there on low boost setting anyway...
PostPosted: Thu May 14, 2009 12:15 am
Mine is pretty quiet and just a straight through 2.5" system as well, the turbo blocks most of the noise.
My induction sound, turbo spooling and BOV are heaps louder than whats coming out the back :)
PostPosted: Thu May 14, 2009 8:00 am
I used Chicken wire, wraped it up as tight as possible, (I then sprayed it black, just incase they looked down the pipe) jamed it in as far as possible with a broom stick (Pulled it out with a coat hanger after RTA) got me through
*Reasonable pricing
*I come to you..
Jay: 0431404607
Users browsing this forum: No registered users and 30 guests
