It is currently Fri Jul 18, 2025 11:41 am
 Post subject: Flywheel
PostPosted: Mon Feb 28, 2005 8:36 pm
I pulled the flywheel off the motor and the three points at which the pressure plate bolts to looks like it has had an angle grinder used on it. Why would someone do this? The clutch shuddered like buggery so if the pressure plate was sitting at an angle I guess it would be the cause. Comments? I guess I might need another flywheel.
Chris
Everything I like is either
PostPosted: Mon Feb 28, 2005 8:47 pm
I guess they'd do it cos they're an idiot! sounds a lot like you'll need a new flywheel....
can you post a pic? I wouldn't mind seeing what they've done
PostPosted: Mon Feb 28, 2005 8:53 pm
I could email you one. I still haven't figured out how to post pics, not for want of trying mind you.
Chris
Users browsing this forum: Bing [Bot] and 102 guests
