It is currently Fri Jun 27, 2025 8:59 am
 Post subject: Sump plug......
PostPosted: Tue May 19, 2009 8:51 pm
Ok, picked up a magnetic sump plug today and soon as i looked at it thought to myself sure mine is bigger than this(Also remembered thinking i thought my sump plug was BIG)
So got home and checked it straight away, yep my sump plug must have been tightened with a BFB in a previous life and fooked the thread, so my question is whats best to do...
1. drill reccess in current sump plug and fit magnet i can get from a mate that came out of a mini magnet sump plug(was loose he pulled it out)
2. Match current sump plug with long ish bolt, then machine it down aka extend magnet sump plug and reccess magnet in end so further into gearbox.
3. Match current sump plug, drill and tap to standard sump plug size and locktite it in and use the standard magnetic plug.
Also whats good for sticking magnet in if that best idea?!
Ps. Also fitted rare earth magnets on filter, just in case you wondering.
Thanks
PostPosted: Tue May 19, 2009 9:44 pm
What I did, so I could use the original sump plug:
Drilled / tap out old stripped thread to 3/4" UNF (make sure you tap thread square, otherwise flange will not seal)
Screw the new high tensile threaded bush into sump using a copper washer on the flange and loctite. Hey presto, new High Tensile thread to screw your original sump plug into. Will never strip again.
Hope this helps. Worked for me.
Steve
"Boris" - '69 Cooper S Mk 2
PostPosted: Tue May 19, 2009 9:52 pm
If you can have the plug out for a week, post to me and I'll fit a super strength `rare earth' magnet into it. NO charge.
I did one last week, same problem. :wink:
Or you can do it. I used a 1/4 dia x 1/2" long magnet. Drilled the hole 6.5mm diameter x 4.5mm deep and used Loctite 609.
I pushed it into the hole without Loctite just to try fit, could not pull it back out without using pliers. Bloody strong they are. :lol:
PostPosted: Tue May 19, 2009 10:16 pm
is that possible to tap gearbox casing in situ!?
Best way to flush filings!?
PostPosted: Tue May 19, 2009 10:21 pm
lots of oil :-)
PostPosted: Tue May 19, 2009 10:24 pm
Yep you can do it in situ, put grease all over the drill and also the tap to catch most of the swarf. Then 1/2 fill it with cheap oil, drain out to get any remaining swarf, then fill again.
If you are tapping it out to fit a bigger plug, it is difficult to get the end face square. If not square the plug will leak.
The way 4myego did it is a better solution.
PostPosted: Tue May 19, 2009 10:32 pm
will check the thread on current oversize plug to check size etc.. may be the better solution to take you up on the offer Doc as mini ain't going anywhere for a while!
Thinking it maybe over tapped with current thread as pretty course looking!
PostPosted: Tue May 19, 2009 10:57 pm
Tomboss Breweros
[quote="4myego"]Image[quote]
Excellent, better than a re-coil and it will allow for any slight angle difference.
My latest mini i also found a bigger bolt in the sump with no magnet, so i did a dodge and glued (araldite) 6 neo magnets to the end of the thread. With the bolt in the vice i couldn't snap them off. From outside the box that plug can hold up a 13/16 1/2 drive socket.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Wed May 20, 2009 7:58 am
The original sump plug thread was 5/8" UNC.
The one I put a magnet in last week was tapped out to 3/4" UNC. The plug was a shortened hex setscrew.
These coarse threads are better in alloy than UNF, as they are deeper and less likely to strip if overtightened.
PostPosted: Wed May 20, 2009 8:19 am
My helicoiled sump plug hole is leaking with the engine just sitting there so I guess the hole was not quite square. Plug is tight with a new copper washer.
Wondering if I araldite a copper washer to the sump - do the plug up until it just touchs and 'self levels' the washer against the plug and let the araldite fill the gap. I'll pull the plug out when the araldite is green so it doesn't lock it in place.
David L
PostPosted: Wed May 20, 2009 8:39 am
What about a hydraulic plug? Get one with an 'o' ring on it?
Would a copper washer be necessary then?
PostPosted: Wed May 20, 2009 8:47 am
if u need a ergent fix do what a member on hear did a few months ago got a cork and jammed it in his sump plug hole he recons it was good for up to 100km :?
PostPosted: Wed May 20, 2009 2:44 pm
:lol: that would be me :) Yea it works wonders :P I would fully recomend it! I now just have a brass plug, with gas fitting thread on it, and drilled a hole down the inside and placed a magnet in there with 5 minute alridite, works fine, its held for over 900km since. :)
PostPosted: Wed May 20, 2009 9:02 pm
This space for rent
You could always consider one of these. Been thinking about grabbing one to play with...
PostPosted: Thu May 21, 2009 2:00 pm
oooo aaaahhhh
Users browsing this forum: No registered users and 72 guests
