It is currently Sun Jul 20, 2025 10:15 pm
Post new topic Reply to topic  [ 83 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Thu May 21, 2009 12:05 pm
yes well they pulled some of the car apart to weld rust etc.
it's full of mud inside carpet is soaked the back seats with this oil mucky like stains.
the air con humidifier that sits under the dash was sitting on the floor so it's full of water.
the sills are full of water.
it does not look the same from my place to to shop.
i have before photo's of the car, as i said was all new parts new breaks bearings etc all under the car, it is so muddy & dirty like you would not believe.
the shop had pulled apart some parts to fit others like wire my dash etc so dash was out. ( saved my dash ) i think. the water was not that high so it should be ok, well those parts they did pull of for the moment sat on the floor in box's ('new parts') they all soaked in muddy mucky water.
looking at the engine it does not look to bad, i think a good flush will be ok.
they wont let me touch the car until the bloke comes to check it from insurance, so it's really killing me watching it slowly rot! even though it has only been a day lol.
still it's my mini!!
i do have lots of photo's of the build & all receipts of the car.
i will keep everyone updated & after this is sorted ill be getting the insurance the next day lol. i wish i knew this before. lesson learned.
PostPosted: Thu May 21, 2009 8:20 pm
If the water that went into your car was anything like the water that flowed near my place, it was full of mud silt. That stuff won't come out of an engine just by putting a few lots of new oil through it. The car may run but the wear rate inside the donk would have to be high. A strip down, clean and re-assemble would have to be the right thing to do.
M
PostPosted: Thu May 21, 2009 8:40 pm
i told him that & said a few mini shops recommended that it would need to be stripped & cleaned.
he said fiddle sticks of it will need a rebuild! it's just water mate.
ill need to go over the car with a fine tooth comb.
it was dirty mucky muddy water though & not fresh crystal clear water would it matter?
receipts, receipts, receipts, receipts and Photo's, Photo's, Photo's, Photo's, would you agree Graham
PostPosted: Thu May 21, 2009 8:44 pm
This space for rent
Have a look inside an enclosed space where the water invaded. If it's full of silt, then your engine is full of silt. Pure and simple.
PostPosted: Thu May 21, 2009 9:40 pm
cool thanks mate.
i will investigate all this tomorrow.
ill look for the silt etc.
PostPosted: Fri May 22, 2009 1:10 am
mate hang in there,take the time to listen to what the other blokes are saying,obviously you give a crap about your mini,all i can say is dont give up.your car is worth saving,i know i would be pissed off if it happened to me,think of the bigger picture,we all have dedicated ourselves to owning a car that brings great pleasure,well lets face it,if your on this forum then your a believer.sorry to hear of your plight....andy
First you get the money,then you get the power,then you get the Mini.
 Post subject: Mistake
PostPosted: Fri May 22, 2009 5:17 am
You should have stuck with a repairer at Higher ground even though you thought they were a bit more expensive. See what happened with getting the job done cheaper. Is it worth the money you saved getting your car drowned ? It sounds like you will need to strip the car from all trim and stuff from the windows down and leave it in the sun with the windows open for a few days to dry it out. Regardin the electrics there should not be much damage to things providing car is not left under water for too long Water dries out and a bit of CRC on connections will work wonders. Any switches and instruments that went under water will need extensive professional attention. Things like srarter motor and Alternator will need an overhaul and a major going over. Make sure you hit the insurer hard after all the work and money your put into that car. And do not sine till it is perfect again. Faults will keep returning long after the flood reseeds. Sorry to hear this Nick and good luck with the cleanup mate.
"Let us remove your "SHORTS"
PostPosted: Fri May 22, 2009 7:32 am
Use the 'white glove' trick (a white hanky over the end of a finger will do) and wipe around a few spots (enclosed as suggested) - the white will show the dirt.
Silt is full of silica - the second hardest substance to diamond - imagine grinding paste in your bearings
David L
PostPosted: Fri May 22, 2009 10:12 am
There is no guaranttee the engine is full of silt. In any case the engine wasn't running when it was under water. The major places the water can get in is through the dip stick, rocker cap, breathers and carby. All are fairly restricted openings.
Oil floats on water and as the engine hasn't started or turned over it wont be frothed or through the oil galleries.
Do a systematic first drain of the sump. Drain it into a clear container. The water (if its in the engine) should drain out first. Stop the draining as soon as the oild begins to come out by putting the sump plug back.
Just let the water sit and settle - if there is heaps of silt you will see it settle in the clear container. By all mean then begin the engine oil flushing. The water portion and its silt content will give you an idea of if a strip and clean. A rebuild is not indicated if the engine hasn't been turned over.
Mike
PostPosted: Fri May 22, 2009 11:09 am
This space for rent
A question for those who've been here more than a suggestion, but if the water comes out of the engine silty would it be advisable to flush the engine with a light oil such as diesel, or a solvent such as petrol in order to disperse the silt?
PostPosted: Fri May 22, 2009 12:55 pm
Update. everyone.
i did what you all said I checked over the engine & other parts breaks etc used white glove there is fine sandy & muddy substance (silt)? past the dipstick & all over around the car on my brakes front & back, inside is muddy & seats & carpet & door cards back & front side pockets are wet still with mud & silt.
the aircon Humidifiers is full of water & silt i assume that's gone?
I hope his insurance covers it, Hope to god i really do! :oops: if they i will be ok & everything that needs to be done should be done.
i hope they will pay me the money ill need to repair it & ill take my car else where.
i cant believe after working on this bloody car for so long so hard, your pride & joy is ****ed it's really upsetting me i got to start again almost.
im gonna lay down i feel sick this is doing my head in.
PostPosted: Fri May 22, 2009 8:56 pm
Slow-Po
Another brisbane garage....
PostPosted: Fri May 22, 2009 8:58 pm
Phew, that was lucky. No major damage there.
PostPosted: Fri May 22, 2009 9:26 pm
Another bunch ov soggy wank packs YAY Bring more rain to reach the ones on the molnars
Users browsing this forum: No registered users and 69 guests
