It is currently Sun Jul 20, 2025 4:32 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 30, 31, 32, 33, 34, 35, 36 ... 568  Next
PostPosted: Thu May 28, 2009 8:10 pm
I played with the cam timing on the twinky cyl head (a bit) :-) & also started setting up the EFI fuel tank & pump & filter etc ,,, getting it ready to fit the injection stuff :-)
PostPosted: Thu May 28, 2009 8:43 pm
I've been playing with the 850 in preparation for the Cootha Classic this weekend. :D I replaced ignition leads, distributor cap, thermostat housing gasket and adjusted hand brake.
Its amazing how much better all four brakes work after getting the hand brake right.
Now im in the middle of polishing and detailing.
played and experimented with the wiring mainly with the head lights, fuse box and relay
PostPosted: Thu May 28, 2009 9:22 pm
Legally drove on public roads for the 1st time in 18 months.... Its finally registered!! 8)
-James.
Toyota 4EFTE Powered Minivan.
PostPosted: Thu May 28, 2009 9:30 pm
WOOHOO , well done .
PostPosted: Thu May 28, 2009 9:57 pm
Got the Cooper S discs apart... almost completely. Calipers apart and pistons out... just one castle nut on one hub is not coming, soaking in Lanox for another try tomorrow.
PostPosted: Fri May 29, 2009 10:24 am
discovered the rear tyres are rubbing on the trailing arm:(
PostPosted: Fri May 29, 2009 11:42 am
let me guess... wide offset contessas with 165's and standard drums?
this morning, I used my friend's adjustable timing light to check my trigger wheel offset, and just before I checked what needles I have in my carbs - I couldn't remember and now that my ignition is super sparky, I don't need nearly as much fuel - it stinks of petrol
PostPosted: Fri May 29, 2009 12:08 pm
id say so, when i bought them i was told they were LS offset, but cant really do anything about it now as i bought them 2 years ago and only started driving the car recently, have ordered spacer drums.
does anyone know the backspacing, offset etc of LS and wide offset contessas?
PostPosted: Fri May 29, 2009 12:16 pm
pretty sure LS offset contessas won't go on at all with standard drums...
start another thread if you want to discuss offsets etc ;)
PostPosted: Fri May 29, 2009 12:28 pm
ginger ninja
ginger ninja
what did I do on my mini today....absolutely nothing :(
sports850 wrote:
PostPosted: Fri May 29, 2009 3:53 pm
burnt myself on it :lol:
The speedo cable inner fell out and fell on the solinoid, shorted and caught fire :shock: ...i then proceeded to pick it up....DoH!
im a bit retarded today!
PostPosted: Fri May 29, 2009 3:54 pm
Milatsmadmini
replaced the studs for my thermo housing and put a new thermostat in...
PostPosted: Fri May 29, 2009 5:58 pm
cleaned cleaned cleaned my mini she is all dry. engine is good.
sande4d back floor, clean & ready to apply paint. hardly any rust!
PostPosted: Fri May 29, 2009 6:14 pm
Cut a rectangle from clear plastic to block airflow to the oil cooler (cos its so cold down here), changed the oil, gave it a wash and cleaned inisde...all in prep for Sunday's drive to Winton.
Users browsing this forum: Majestic-12 [Bot], minimanic and 74 guests
