It is currently Mon Jul 21, 2025 7:09 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 42, 43, 44, 45, 46, 47, 48 ... 568  Next
PostPosted: Sat Jun 13, 2009 6:55 pm
Continued getting the 1100 engine in, and various associated bit's and pieces. Got most of it done today. Still need to do a few more things before it is ready to fire up.
KB
PostPosted: Sat Jun 13, 2009 9:25 pm
Only a couple of small jobs. Fitted a new washer bottle and relocated my spotties to comply with the regulations.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Sat Jun 13, 2009 9:57 pm
Bought 15 Litres of degreaser for the parts washer and started to clean the Cooper S engine and parts.
Dropped the crankshaft off for a check at Mini Classic and a possible regrind and visited GR in his Aladdins cave to talk about camshaft grinds.
1969 Cooper "S"
1967 Mini Deluxe
2019 MINI F55 Cooper S
PostPosted: Sun Jun 14, 2009 1:29 pm
went to warendyte for coffee and cake with a whole heap of other minis :D :D
PostPosted: Sun Jun 14, 2009 1:36 pm
Drained out the old Castrol Edge 25W/50 and put in KMX 20W/50. It's winter.... (brrrrrrrr).
Charge light was on dimly so I changed the V regulator inside the 17ACR alternator. All good now, has nearly 14V with the lights on. :D
PostPosted: Sun Jun 14, 2009 2:20 pm
resoldered the common indicator wire back on to the base of the stalk.... about to replace the muffler with an old one - came off my blue car I think
PostPosted: Sun Jun 14, 2009 2:29 pm
Removed the hinge strengthener thingys from inside the wheel arches on drivers side :x
Looks like a new inner A panel needed :)
My new Dremel came in handy :D
Good for those tight spots :)
PostPosted: Sun Jun 14, 2009 3:13 pm
dropped front subframe and stripped down......nearly!
stupid trumpets and cones!
mooo, I'm a pig!
PostPosted: Sun Jun 14, 2009 5:59 pm
Location: Burpengary,Brisbane Nth(the better side of Bribane)
Went on a run with the MOCQ Sunshine coast group.Had a lot of fun... :D
https://t.me/pump_upp
PostPosted: Sun Jun 14, 2009 7:04 pm
I had to touch it :twisted: Been rubbing back the engine bay after Por15 and a number of coats of Enamal. I had already polished the fire wall to bling but I could still see Orange Peal so started running it back further. :twisted: where are these white flects comming from, all over it. I think it was from one of the cheaper rattle cans I used.
Why did I touch it
PostPosted: Sun Jun 14, 2009 8:56 pm
Pumped up the suspension using SGC's hydro pump... after I discovered that my grease gun had a leak and all the hydro fluid from the car squirted out all over me.
Took the car for a drive around the block, retorqued everything up, adjusted the toe out. Now all I have to do is try and correct the torque steer.... I mean suspension and steering geometry and get used to the induction noise. :shock:
2008 Prado GXL
PostPosted: Sun Jun 14, 2009 9:16 pm
This space for rent
If you need a hand getting the camber, castor and toe sorted out give me a yell -- I have camber / castor gauges here which I made to set mine up, she drives good 8)
PostPosted: Sun Jun 14, 2009 9:58 pm
I looked at my two today in the garage still covered in mud from the Mini Nationals last weekend.
Maybe if I keep looking long enough the mud might fall off by itself......... :lol: :lol:
Julie.............
PostPosted: Sun Jun 14, 2009 10:10 pm
Actually did this on Saturday. Fitted new bonnet stay and alloy door levers and window winders. Also did some touch ups around the dash ready to puy in dash liners and installed alloy sill plates.....looking good.
It might only have half the engine but its got 4 times the handling...............
PostPosted: Sun Jun 14, 2009 11:17 pm
haven't seen my mini for over 2 weeks now. I miss it so!
tim
Users browsing this forum: bharp831 and 83 guests
