It is currently Sat Aug 23, 2025 10:23 am
Post new topic Reply to topic  [ 66 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
PostPosted: Fri Jun 19, 2009 4:05 pm
swae85 wrote:
TheMiniMan wrote:
ok, here`s my bet,,, the planetary gears (or one of them) has split into a couple (or a few) bits & one of those bits has flung out of the diff carrier & now jammed into the selector fork thingamyjig
I have no idea what you just said :shock:
but it kinda turned me on :lol:
Hee hee,,, translation---> Broke the diff
ar...er...um ,,, & well,,, strange type of turn on :-) but hey, i can talk broken diffs all night if you like :-)
PostPosted: Fri Jun 19, 2009 4:11 pm
ginger ninja
ginger ninja
ahhh now I somewhat understand :) :?
sports850 wrote:
PostPosted: Fri Jun 19, 2009 4:17 pm
As a casual passer by - I have to ask to what bit do you understand :lol: :lol:
Mike
PostPosted: Fri Jun 19, 2009 4:29 pm
ginger ninja
ginger ninja
Mike
:shock: um... no comment :lol:
sports850 wrote:
PostPosted: Fri Jun 19, 2009 4:30 pm
Yes, it would be more interesting if Jess said there was some vibration followed by a loud bang,her diff was broken, she had drained her sump and found a lot of swarf.
PostPosted: Fri Jun 19, 2009 4:32 pm
Hhhmmmm,,, Vibrations,,, Bangs,,, Fluids oozing,,, sounds Volcanic :-)
PostPosted: Fri Jun 19, 2009 4:38 pm
ginger ninja
ginger ninja
*cough* back on topic! (sorry for hijacking your thread Simon :oops:)
sports850 wrote:
PostPosted: Fri Jun 19, 2009 4:55 pm
Yes.
Back to your stuck stick.
PostPosted: Fri Jun 19, 2009 5:00 pm
Jess, Diff's (Diferentials) are complicated things, most of the blokes on here wouldn't be able to describe how they work!
Think about your Mini going around a corner, the inner wheel travels less distance than the outer, a solid axle would do wierd things to the handling!
The diff allows for continued drive to the wheels and to compensate in the speed / distance 'differential' of the inner and outer wheel.
Does that help? :?
Not as raunchy as what Matt said! :roll:
Sir Alec! we are not worthy!
PostPosted: Fri Jun 19, 2009 5:14 pm
that's my bet too Matt... I'll let you know in the morning
Jess, how does that get you randy? there's no mention of hard oiled shafts or greased nipples.....?? edit: bit behind the rest of the innuendo
PostPosted: Fri Jun 19, 2009 6:48 pm
ginger ninja
ginger ninja
lol I was joking! Kinda...I do like a man who works on cars and gets all greasy and then you get handprints on your..... :oops:
sports850 wrote:
PostPosted: Fri Jun 19, 2009 7:38 pm
:shock: Where is a mod when you need one :?: To edit both of these outrageous/extremely suggestive posts in this thread.....disgusting :!: :wink: :P :lol: :lol: :lol:
PostPosted: Fri Jun 19, 2009 9:20 pm
Tomboss Breweros
So much smut.
Now i must go to confession :oops:
simon k wrote:
going gently around a left-hand corner near work this morning and it felt like something in the steering let go, it tried to keep going straight
My car did that once.
simon k wrote:
I got it around the corner and pulled up, switched the engine off and looked over the front end and everything was in place.
I didn't make it around the corner at first, i stopped to turn right across traffic and couldn't get moving until at 5-6000 rpm and a heavy clutch drop it moved, whilst spitting the broken cross pin and 5L of hot oil out the bottom of the gearbox all over the road.
simon k wrote:
I remembered what Doogie said about the last time his diff broke in a motorkhana, he had full drive on one wheel, the car just wanted to go in one direction - same kind of feeling.
Mine felt normal after punching the hole in the gearbox.
simon k wrote:
I probably shouldn't have, but I started the engine again put it in 1st gear and tried to move it - had drive, no noises, but now it's jammed in 1st gear :roll:
bugger! gotta pull it all apart again :roll: :evil:
No jammed gears in mine.
I wasn't popular for staying up till 2am swapping engines over.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Fri Jun 19, 2009 9:56 pm
This space for rent
Mine did it too once, although I didn't give it the boot and didn't drop its guts all over the road :lol: One flat bed later...
PostPosted: Fri Jun 19, 2009 10:53 pm
when you pull the box to pieces it might be time for a few bits like these for it
a quaffe diff out of a honda integra with double helical gears and good cv's
the do fit with a very small amount [less than a milimeter] out of the casing. There are std taper rollers to fit from 40mm carrier to 3" mini casing.
Then you go for a taper roller brg replacement for the pinion and in-put brgs. at least these will take some loads.
www.minisprintgt.com
Users browsing this forum: ken@miniauto and 246 guests
