It is currently Mon Jul 21, 2025 7:08 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 44, 45, 46, 47, 48, 49, 50 ... 568  Next
PostPosted: Thu Jun 18, 2009 5:37 pm
got my new steering wheel, wooden rim, with the rivits in the wheel and out of the rim (I;ve since worked out they were painted. But looks like the expesnive wheel.
http://cgi.ebay.com.au/WOODEN-13-STEERI ... otohosting
PostPosted: Thu Jun 18, 2009 8:44 pm
Cleaned the engine bay and gearbox of the 850 before assembling the 1100 block onto the clean gearbox. Just have to get some paint on the engine bay and subframes before dropping the engine assembly back in.
1964 998 Cooper , 1968 Morris 1100
PostPosted: Thu Jun 18, 2009 8:59 pm
Finally figured out all the hoses from the carby to the charcoal cannister and the crankcase to the carby and the float bowl to the cannister and the..... you get the idea.
First time it has idled properly since I got it a month ago.
Now need to tweak the timing and mixture to get rid of the intermittent flat spot around 2000rpm.
Just had a thought could the flat spot be caused by low oil in the dash pot?
Will have a look in the morning.
1978 Mini S - "FAX"
PostPosted: Sat Jun 20, 2009 8:52 pm
Just got my car back from getting a 45 weber fitted, awesome now! :D :D
PostPosted: Sat Jun 20, 2009 8:56 pm
Pushed it off the trailer and into Mini King's driveway.
KB
PostPosted: Sat Jun 20, 2009 9:05 pm
Desperatly trying to get more shed space for number #3
PostPosted: Sat Jun 20, 2009 9:11 pm
rubbing and priming, took out rubber cones and demolished the trumpets.
Anyone have any half okay cones and trumpets they dont need? Yes?
mooo, I'm a pig!
I think you need to show us some pics.
Kevin why King and Brettis it not the wheel in the pic
PostPosted: Sat Jun 20, 2009 9:14 pm
Pick it up nxt weekend Gamfo,shall bombard you all with pics then :D
PostPosted: Sat Jun 20, 2009 9:53 pm
Gaf,
Had a few bits and pieces needed to get it up and running, and by the time I spend a few hours a weekend on it, and chase 'round for parts it was easier just to pass it over and say get it done. The sooner it is done, the sooner I can register it and advertise it again.
KB
PostPosted: Sat Jun 20, 2009 9:54 pm
Leyland ST project has started. :D
PostPosted: Sat Jun 20, 2009 10:32 pm
I went to 4myego's and fired his 1360S motor up.
Then I went to Lillee's and pumped his hydro up. And drank a few Beez Neez... :P
PostPosted: Sat Jun 20, 2009 10:45 pm
Took scrapper off the trailer and pushed his other motor round ready to go back in.... then boiled the jug...... living near GR seems to be rubbing off on me....
PostPosted: Sat Jun 20, 2009 11:00 pm
Fitted dash cards, lower dash rail chrome trim, steering coloum shroud, made painted and fitted a box for my stereo head unit ( now you can`t see the metal frame on the stereo ). Refitted the front 6 inch splits, painted the gear stick and pedals and polished the union jack painted under the bonnet........i`m glad the day is over :D :D :D :D
It might only have half the engine but its got 4 times the handling...............
PostPosted: Sat Jun 20, 2009 11:32 pm
took my motor out, took the diff out and found my broken teeth, then split the motor off the box and found another few nasties - it never ends
I'm glad to hear you've moved closer to GR - I'm going to send him my cam again, I think I might ask you do to a little prodding to get it done and posted back ;)
Users browsing this forum: bharp831 and 82 guests
