It is currently Sun Jul 20, 2025 8:32 pm
PostPosted: Thu Mar 03, 2005 5:57 pm
l have tried 2 different alternators in my mini that will only initially start charging once the motor is reved to 4000 rpm One is a lucas alternator, the other of a nissan pusar q .
Has any body else come across this problem. Checking the wiring diagram in my mini manual they are attached correctly to the battery, ignition and warning light wiring.
PostPosted: Thu Mar 03, 2005 5:59 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
the black box on the driverside of the engine bay is the reg in the older cars might be stuffed
makka
PostPosted: Thu Mar 03, 2005 6:09 pm
Both alternators have built in regulators. l am also using the wiring harness out of my old clubman which is designed for alternators with built in regulators
PostPosted: Thu Mar 03, 2005 6:32 pm
Clean all terminals.. :wink: for buid Up
PostPosted: Thu Mar 03, 2005 6:35 pm
i had kinda this problem where my radio was conected to the battery instead of the ignition and always had to get it jump started and the alternator didnt seem like it worked but it was just the radio draining the power
PostPosted: Thu Mar 03, 2005 7:13 pm
FUSE
someone i now had this problem and he went and got a rover alternator
and it ended up just being a fuse :shock: :D
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Thu Mar 03, 2005 7:27 pm
the radion would have been drainin the battery because there is a wire that u have to connect to the key so it turns off. or just make up another switch.
PostPosted: Sat Mar 05, 2005 5:03 am
The Bosch alternator being a much higher output unit than the Lucas needs a much tighter belt. Tighten it up and I reckon you'll see the difference. A good indicator that the belt is tight enough is if you press the belt down while spining the alternator puley you cant make the belt stay stationary (ie slide on the puley) no matter how hard you press.
PostPosted: Sat Mar 05, 2005 5:58 am
Also, check that the alternator pulley is not worn. The pressed metal ones wear badly to a U shape and then the belt slips when running. I changed the one on my EA Ford (Bosch alternator, similar to Pulsar one) to a 1 piece cast iron pulley, no more problem.
Salvaged this pulley from the local auto leccy for nix. :wink:
Users browsing this forum: Scoop and 98 guests
