It is currently Sat Jul 19, 2025 7:41 pm
Post new topic Reply to topic  [ 113 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6 ... 8  Next
PostPosted: Fri Mar 04, 2005 11:58 am
people think kazjim's exisiting turbo setup would run out of puff in a 1360 before 6000rpm? at bout 8psi
68matic: "i havent seen much head in my life "
PostPosted: Fri Mar 04, 2005 12:05 pm
thats why its good on a 998 :wink:
PostPosted: Fri Mar 04, 2005 12:12 pm
Probably would.. but then again... any turbo is more than capable of destroying ANY engine if you let if have its way !!
keep boost below 12Psi and everything would be cool i reckon....
J
PostPosted: Fri Mar 04, 2005 12:21 pm
thats still pretty high isnt it?
PostPosted: Fri Mar 04, 2005 12:28 pm
Anything with over 8:1 compression would struggle with 12PSI !
J
PostPosted: Fri Mar 04, 2005 1:42 pm
general rule of thumb over 10 psi a intercooler is needed.
i am running 7.8:1 comp and run upto 16psi with no problems yet over 16 and i oftern blow head gaskets. with my setup anything over 12 psi and my intake temp gets up to 100 degress according to my multi meter.
so my new motor is in the early stages but will be running much higher boost and a big cooler to get ideal temp of 15 to 20 degrees.
BK450 gasket and Cosworth forged pistons help.
100% Pure A Series Turbo
PostPosted: Fri Mar 04, 2005 1:52 pm
what compresion would you run?
PostPosted: Fri Mar 04, 2005 1:54 pm
7.5:1 here...
yep, head gaskets CAN be problem, but rather that than split bores, melted pistons, burned valves etc etc etc...
The Head Gasket becomes a FUSE to save the rest of it !
Later
J
PostPosted: Fri Mar 04, 2005 1:57 pm
do you have deep dish pistons or big head chambers?
PostPosted: Fri Mar 04, 2005 2:42 pm
kazjim wrote:
Kev, was going to say that....
ACL....not a problem yet !
J
I spoke to Greg at Karcraft and he's going to stock them. 8)
PostPosted: Fri Mar 04, 2005 2:45 pm
Deep Dish.. same castings as the "van" castings, but in a high-silicon alloy
Dr - good news... I'll give you some $$$ next time we meet up and maybe you can grab me a few..... ?
I'll need at least one for the head i have to drop in to you..... :twisted:
J
PostPosted: Fri Mar 04, 2005 2:49 pm
James,
Saw a quote from somebody the other day that a stock 940 (or 1316 for that matter) head flows better than a worked 295.
Maybe I just sell one back to you with unleaded ex seats in it?? :P
PostPosted: Fri Mar 04, 2005 4:22 pm
but then we have to pocket the block..... hhhmmmmmm
J
PostPosted: Fri Mar 04, 2005 4:25 pm
Sure do :?
PostPosted: Fri Mar 04, 2005 4:31 pm
pocket'd block = lower compression ratio = more boost ;)
(well, a bit)
