It is currently Wed Jul 23, 2025 10:05 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 52, 53, 54, 55, 56, 57, 58 ... 568  Next
PostPosted: Sat Jul 04, 2009 5:46 pm
HAd to pull the head off scrapper as a manifold snapped in the head. Got the next door neighbour to pull our a snapped manifold stud. Thanks mate, cuppa tea will be ready anytime you pop over.
All good now.
PostPosted: Sat Jul 04, 2009 6:01 pm
did modify the oil pressure relief valve to 9/16 ball bearing
PostPosted: Sat Jul 04, 2009 6:02 pm
Dylan filled his mini up with water!
PostPosted: Sat Jul 04, 2009 8:30 pm
Drove Gonzo to the sunshine coast. didnt miss a beat. :D
PostPosted: Sat Jul 04, 2009 9:53 pm
Did you do it :shock:
PostPosted: Sat Jul 04, 2009 9:54 pm
I decked a 1098 block and a 12G295 head for a Newcastle member. :wink:
PostPosted: Sat Jul 04, 2009 10:38 pm
He used his own, but it wasn't enough, so then he used mine. :lol:
PostPosted: Sat Jul 04, 2009 10:40 pm
went for a wander around melb to promote the mini show :)
PostPosted: Sat Jul 04, 2009 10:41 pm
painted some engine bay parts
PostPosted: Sun Jul 05, 2009 1:45 pm
Tuneup time for the 1360...
Adjusted the rockers to .021"/.022" inlet/exhaust. As GR specifies for an RE282 cam and 1.5 rockers.
Closed the plugs back up to .032" (Pulsar dizzy and GT40R coil).
Timing is still perfect (has belt drive kit and electronic dizzy, hard to beat).
Didn't touch the carby, the 45 Dellorto has stayed in tune for years. :D
All ready for dyno day now chaps.:mrgreen:
PostPosted: Sun Jul 05, 2009 4:54 pm
Milatsmadmini
took the moke for a drive... needs a good tune sometime soon... the smoke screen at the lights is sometimes a cause for concern :lol:
started to make a bikini top for the moke out of marine vinyl.... should help with the wind burn :P
PostPosted: Sun Jul 05, 2009 6:42 pm
Gave the Cooper S a run at the Bryant Park hillclimb in the Haunted Hills near Moe. It was the first time they'd used the Figure-8 version of the track, so it took a bit of learning. The weather was freezing but at least it dried out during the day -Great track :D .
Curly
PostPosted: Sun Jul 05, 2009 6:51 pm
My Mini taught me some new skills today-
I learnt how to fill holes with the MIG
I learnt the you clean the surrounding metal with the flapper wheel BEFORE you cut a piece of metal to fit a gap.
and that out of the two methods - cutting and inerting a piece is easier to grind back then grinding back lot of weld in a plug.
The door frame is coming along nicely.
David L
PostPosted: Sun Jul 05, 2009 7:15 pm
I tried my hand at upholstering today and totally sucked at it.
I've got my van in at the auto trimmers getting the rear all lined and better looking for the mini50 show and thought I'd save some time and money by covering the speaker boxes myself.
Not a wise move. I think the trimmers might have a @#$k up to fix as well. :roll:
Image Image
PostPosted: Sun Jul 05, 2009 8:05 pm
Forgot earlier - also bought an oil filter, spark plugs and some coolant
TIP:- don't fill the radiator with the heater hose disconnected :roll:
David L
