It is currently Tue Jul 15, 2025 9:05 am
 Post subject: Now I've done it!
PostPosted: Fri Jul 03, 2009 9:05 pm
Oh man... I've done some really stupid things in my life, but I think i might have just outdone myself >_<. A long-suffering red clubby is going to be really famous tomorrow.
I'll keep it a secret until tomorrow, then I'll post up a pic before I leave the house.
Hint: it involves music
Edit Sat 4 July:
Image Image Image
Headed for the Michael Jackson Mass Moonwalk this evening in Martin Place:
http://www.facebook.com/group.php?gid=9 ... 389&ref=mf
PostPosted: Fri Jul 03, 2009 10:16 pm
does it include strippers??
PostPosted: Fri Jul 03, 2009 10:22 pm
and midgets?
PostPosted: Fri Jul 03, 2009 10:23 pm
midget strippers dancing in the back of a mini van, disco lights and some doof doof.
PostPosted: Sat Jul 04, 2009 10:10 am
Well it's tomorrow?????
Wheres the pics of the midget strippers dancing in the back of a mini van with disco lights and some doof doof. :D I hope you were taught to share :P
PostPosted: Sat Jul 04, 2009 1:37 pm
OP edited 8)
Yes it's loud... earplugs, check!
PostPosted: Sun Jul 05, 2009 10:14 pm
Pictures:
ImageImage Image
Videos:
http://www.youtube.com/watch?v=ofSYiaTHLyw
http://www.youtube.com/watch?v=2bZ67Pw44_g
50 YEARS OF LOVE: MINI AND MJ
PostPosted: Sun Jul 05, 2009 10:26 pm
Tomboss Breweros
I might have a van, i might be short, there might be disco lights and doof doof but i am not a stripper.
Top effort headgasket, you would have put smiles on a lot of faces :D
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Jul 05, 2009 10:30 pm
hah hear the voice..."your walking backwards, thats all your doing!"
PostPosted: Sun Jul 05, 2009 10:33 pm
I must say, driving that car with MJ cranked up is even wierder than usual. I had people following me in formation behind, and people coming up alongside and giving me the thumbs up. I even got requests :D
I wanted to take a vid with my camera, but it ran out of battery! Typical!!!
Any way the sound system specs are:
- 1x 2x150W Response amp.
- 2x 120W cheapo party speakers (8 ohms)
- 1x Marine 12V (110Ah) battery that is still not flat after about 2hrs of
- powering the above at full volume
- Some 4 gauge cable for carrying 30A to the amp, and speaker cable
- A 120A circuitbreaker with built in voltage display so I could keep an eye on the power.
- Laptop with winamp for supply the tunes
- Car battery + alternator as backup
I wasn't sure if the marine battery would hold out for 3 hours, but it did. But then again, I probably wasn't actually doing the full 240 W because I was using 8 ohm speakers instead of 4 (permitted by the amp). Initially I planned to run them in parallel in bridged mono configuration, but it turned out to be loud enough in stereo.
But this gives me a very bad idea.... it means I can buy another pair of speakers and run each pair in parallel off the same amp.
Some interesting observations:
- Was nice to see the batt voltage slump to 11.7 during bass beats and then back up to 12.0
- Switching over to the car battery, the alternator was able to maintain 13.1 - 13.4 V driving at night with the stereo cranked to full volume.
- A mini roof can support 2 20kg (?) speakers weight. It dented in a bit to be flat, but popped out when I took the speakers off
This car never stops amazing...
Buhaha....
Edit: A had a heart attack when I first rocked up to the place. I switched the jumper leads from the car batt to the marine batt, but forgot to watch the polarization. :roll: :roll: I freaked thinking I'd blown my shiny new amp and I'd have to use my pissy 4x50. Luckily it just blew a 25A fuse and I brought spares. I put the I in idiotproof systems.
Edit2: Reformatted amp specs, theres only 1 amp.
PostPosted: Sun Jul 05, 2009 10:41 pm
Tomboss Breweros
headgasket wrote:
- 2x150W Response amp.
- 2x120W cheapo party speakers (8 ohms)
- Some 4 gauge cable for carrying 30A to the AMP, and speaker cable
Buhaha....
Thats a good effort.
In my van there are 3 amps collectively 2000w
1 x 700cca battery
85A alternator (63A couldn't keep up)
A 1 farad cap
Not running i had the stereo on for about 8 hours at about 1/3 - 1/2 volume and the drain got to about 11V. It started the next day.
Your system should well outdo that, and probably push more SPL :oops:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Jul 12, 2009 9:51 pm
Check this out:
http://www.mediavr.com/flash/mjackson.htm
PostPosted: Mon Jul 13, 2009 6:16 am
pretty cool :D
seems as though everyone had a good time
Users browsing this forum: Bing [Bot] and 84 guests
