It is currently Fri Jun 20, 2025 12:04 am
Post new topic Reply to topic  [ 193 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11 ... 13  Next
PostPosted: Mon Jul 06, 2009 4:51 am
GR wrote:
The head is fitted with the latest valve inserts that are wery hard
and shrunk into the head with 6 to 7tho interferance fit so they
will not come out
Hi GR! Thanks for your awnser! :)
I think this head would be my first choice if I had the money to spend on an engine.
How would your new cam design perform with a sligthly worked (valve guide boses removed) 'big valve' 12G940? What I want is a road going engine that can pull strong and rev, but mustn't neccesarily. It sounds like it could do that job?
Best regards,
Jan
Talking about porousity; this is a late Rover gearbox casing (DAM5626, late SPI era). Is it a railway then? :D
http://www.mini-mayfair.net/temp/schweizerkaese.jpg
http://www.mini-mayfair.net/temp/nochmehrkaese.jpg
http://www.mini-mayfair.net/temp/undnochmalkaese.jpg
http://www.mini-mayfair.net/temp/hauptlagerkaese.jpg
PostPosted: Mon Jul 06, 2009 1:49 pm
ausmini mod
ausmini mod
david rosenthal wrote:
pristic wrote:
Howdy,
In regards to power yeah they make similar on the surface... but:
The crossflow heads pulls from down low up to 7000-7500rpm
While the bikes make power at 9500-10500rpm
The Elder head will make more torque. 20-30ft/lb than the bike heads will...
Torque is what you feel! Torque is what everyone is chasing!
I know what i would get... its simple.
Pete
Interesting comment. Now I am only a pig-iron polisher and I am dumb as dog sh*t so PLEASE explain the reasons for your comments
David, with all due respect - No. I wont... lets not turn this into an online punch up... drop it.
PostPosted: Mon Jul 06, 2009 2:56 pm
Couple of questions. Jumping the gun a bit I guess:
Is the manifold at the moment only for twin webbers?
Will this fit under a standard bonnet, or is it a long branch manifold?
If it won't fit with webbers. Could you fit Amals (as were on the 8 port heads) with a hope to fitting under the bonnet?
Thanks, this looks the duck guts at the moment and watch with great interest. :shock:
2008 Prado GXL
PostPosted: Mon Jul 06, 2009 3:16 pm
Hi Pete, I can assure you I have no desire to allow this to degenerate into a online sh*t fight in any way shape or form. A rational informative discussion, yes.
I spoke to GR on friday and we seem to be of the same opinion that a little more understanding of the physics and calculations where we derive our infomation may be of some benefit to some people trying to understanding the complex issuses with engine design and performance.
I can also assure you that I hold GR in great esteem as he works out the figures from hard facts backed up by calculations and testing and is a" true professional" in this line of work. I also think the same of Matt,and Doc.
some people live on "folk law" others derive their information from facts and knowlege.
I have been down this road before just recently,so here ends my comments on the subject.
www.minisprintgt.com
PostPosted: Mon Jul 06, 2009 3:45 pm
I am enjoying this thread very much so, as i know very little about making engines go hard and always assumed bigger is better. So reading all this im learning that this is not always the case in all circumstances.
Thanks GR, Doc, Mat and David for all your comments
Imreally looking forward to seeing these heads in there final finished ready to bolt on form that can be sold
PostPosted: Mon Jul 06, 2009 3:51 pm
GR,
Is it possible to extrusion hone those heads and make the task of porting them a lot easier?
I have heard that some heads dont like the extrusion hone process due to the sharp angular bends.
Interested to find out.
Tricky
P.S. Simon, I'm back!
PostPosted: Mon Jul 06, 2009 8:19 pm
Oh dear, worry, worry...
Hi Jan
The new cam will work very well with your head, during testing
we thought the head i made for it may have been giving us
a false indication of how the cam was performing so we bolted
stock std 12g940 head on and it still made 101ftlb of torque
and 104 hp but the spread of torque was not as good over the
full rpm range .
Graham Russell
PostPosted: Mon Jul 06, 2009 8:45 pm
Hi Dave
It will be a tight fit to fit the webers under the bonnet of the round
nose(thats why we all should drive CLUBMANS! oh sorry Just
dreaming) but any of the motor bike carbies are good 36mm or
38mm will give good torque and hp.
To get the best out of any mini be it a 5 / 7/ or 8 port they need
a manifold at least 5 to 6 ins long.
Hi Tricky
Extrusion honing has its place but not on tight turn it just
seems to take the metal off in the wrong places, in
saying that on manifolds ive had done it works very well
the only thing wrong it tends to make the runners to
smooth but this is ok if your only running air through it
as with fuel injection not carbies as the fuel tends to stick
to the walls of the manifold
Graham Russell
PostPosted: Mon Jul 06, 2009 10:20 pm
Hi GR
Your new cam (have you chosen a name yet) how does it compare to say your RE13 profile in terms of performance at idle, mid range and top end.
The engine in my Mini goes pretty well with your RE13 cam proile, 1360cc engine.
I also have a Riley Elf that will need an engine sooner or later, which will also be a 1360cc.
Your head looks exciting
I also miss your write ups in Mini Experience are you intending on doing more.
How about how to set up Su carbs or dizzy
Regards
Bernard
PostPosted: Mon Jul 06, 2009 10:29 pm
Hi Graham,
Just wondering how far off these heads are from being available?
Also (a little off topic), are your pistons available in +.020" for 1275's?
Thanks for sharing all this info with us, makes for great reading!
Andrew
PostPosted: Tue Jul 07, 2009 1:15 pm
Those ports look the dogs bollocks.
PostPosted: Tue Jul 07, 2009 4:36 pm
Hi Graham
How close is your new cam to the RE282 in my 1411cc engine?
How close is the cam/12G940 head combination to mine?
If it is reasonably close, then I could arrange for Jan to come over and have a test drive at the next slalom.
On another forum where I linked this thread, a popular member posted this
guru_1071 wrote:
......'I finally got one of the seven port ken elder heads to play with,this will be without a doubt the best after market cylinder head on the market today including all sixteen valve heads.'.....
this is some claim! im not sure how a 7 port is going to produce more torque and bhp than an 8 port - particually as low down as an 8 port can? - certainly none of the current ones on the market have been able to do it, they only seem to provide the goods at high rpms.....
im sure the boys at KAD might have something to say about an elder head making more than a well sorted kad motor!!!
sounds like a bit of sellers license if you ask me, still, whats that saying?
....'when the flag drops, the bull crap stops!'......... :lol:
Any comments Graham?
michael mckellar
PostPosted: Tue Jul 07, 2009 6:15 pm
850man wrote:
The Elder 8 port head i have seen was full of poristy holes and it failed the pressure test twice. Most of the holes tho, can be welded up to fix. there is also a mixture of UNF & metric threads. the head is new but has been sitting around for some time so i guess it was one of the eairler castings.
I have spoken to both Ken Elder and Graham Russell inregards to the history of the 8 port head in question, It is a very early 8 port head that was to be used for assessment only and to be returned to Ken, not to be sold but obviously it didn't get make it for whatever reason.
It was purchased a few years ago at a large swap meet in Victoria and stored. Now the purchaser has a use for it and it has ended up in my workshop so it can be used in their project...........
Yes this head has its flaws and now we know why. The place where the head is having the machine work completed has said it is quite a good head and once completed it will be a very good cylinder head.
Thanks to both Ken and Graham for their help and information in regards to this. Im glad we also got it all sorted out. Catch up with you soon.
Cheers Scott
PostPosted: Tue Jul 07, 2009 6:58 pm
Hi MICK
I have to answer your post first I LOVE A CHALANGE Bring on
the poms and ill put my money where my mouth is bring on your
8 ports and any after market head out of england and ill make
more torque than any of them and match them with hp or beat
them SAME DYNO WHERE DO WE MEET and ill put up a $1000
if some one will match it, send it to them mick
Graham Russell
PostPosted: Tue Jul 07, 2009 7:27 pm
afh001 wrote:
Hi Graham,
Andrew
I think GR may have missed this one. GR's pistons don't come in 20 over, the smallest is a little over a 60 over, can't remember exactly. Dependent on your use the Hypertecs will work in that oversize.
Aaron
Users browsing this forum: Google [Bot] and 126 guests
