It is currently Wed Jul 16, 2025 2:32 pm
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Thu Mar 03, 2005 8:03 pm
CLUBMAN wrote:
is it using the same block at the 1310 special?
what is being done while its apart?
Nope- this time it's a 1275 auto block, we bored it from 1293 straight to 1360.. :shock:
Block has modified oilways to suit manual box.
I'll use the same big ported head, a `revised' RE-13 cam, and an S crank & rods again.
I've got the block back, now need to strip my other motor to get S crank & rods, get 'em balanced with flywheel etc, fit pistons and chuck together.
Box is the same MK2 S, but it might just get the 3.44 diff swapped out for a 3.647. Gotta outdrag kazjim more down the straight at Wakefield Pk.. :P
PostPosted: Thu Mar 03, 2005 8:12 pm
mmm,i wanna go a quicker accel diff.dunno,hopefully ill end up with kazjims turbo set up,ill see how i go from there,more than likley gearbox will die
BRICKWORX RACING
872-874 South Rd
Edwardstown
SA 5039
PH: 8297 9494
FAX: 8297 7133
PostPosted: Fri Mar 04, 2005 9:34 am
just wait til the turbo's in, with all its goodies and I'll drag anyone except 13sec as his has already left the planet on an outbound course! 8) :shock:
68matic: "i havent seen much head in my life "
PostPosted: Fri Mar 04, 2005 1:59 pm
Sorry Kev the Mike's motor is in and just have to put all the additionals on.
I'd be interested to see your motor when its on the bench Dyno.. :shock: 8)
PostPosted: Fri Mar 04, 2005 4:13 pm
Original post from Mininfinity
http://www.minifinity.com/index.php?nam ... ic&t=16271
