It is currently Sat Jul 19, 2025 7:50 pm
 Post subject: gearbox bearing whine
PostPosted: Fri Jul 10, 2009 9:00 pm
hellooooo,
had a nice whine coming from my gearbox for a while now. doing a shell swap over the next couple months to an 88 rover. so while the engine is out i want to get rid of that whine so transport sa dont query it when i get it inspected.
its an a+ engine and box, it whines when i am sitting in neutral with foot off clutch, goes away when foot it on the clutch.
it whines while acceleration/crusing at speed. seems to quietn down alot apon decelerating.
what bearings could it possibly be? ill replace all the bearings on that side of the box
thanks alot
Matt
PostPosted: Fri Jul 10, 2009 9:07 pm
clutch thrust bearing - just stick a few slices of cheese in through the hole in the flywheel housing and it'll be happy
PostPosted: Fri Jul 10, 2009 9:09 pm
its not the thrust bearing. i put a new one on
the noise goes away when i push the clutch to the floor
PostPosted: Fri Jul 10, 2009 9:13 pm
i agree with simon if the noise gors away when clutch pushed in then thrust bearing
PostPosted: Fri Jul 10, 2009 9:16 pm
wait which thrust bearing are we talking about
the one on the end of the clutch fork or the one behind the primary gear?
PostPosted: Fri Jul 10, 2009 9:17 pm
foot on clutch noise dissapears, foot off noise returns. noise under load ,dissapears under over-run.
the brgs on the idler gear or the thrust washer is grinding it's way thru the gearbox case
www.minisprintgt.com
PostPosted: Fri Jul 10, 2009 9:29 pm
awsom thanks for that david
PostPosted: Fri Jul 10, 2009 9:32 pm
most a series boxes whine coz at some stage they have been run with buggered bearings in them and the owners have neglected. later when the bearings have been changed the gear train has now got an angled wear pattern on it so that is he cause of the whine. Just like the sound of straight cuts but softer.
PostPosted: Fri Jul 10, 2009 9:34 pm
yeh except my whine is no wear near that loud.
ive never had a problem with this box
PostPosted: Fri Jul 10, 2009 9:35 pm
there is nothing wrong with a bit of a whine from a gearbox as long as it drowns out the whine from the missus
PostPosted: Fri Jul 10, 2009 9:39 pm
well said!
PostPosted: Fri Jul 10, 2009 9:57 pm
like I said, stick some cheese in it
PostPosted: Fri Jul 10, 2009 10:06 pm
coon/ bega/ sliced/ block/shreded simon i think you need to be a little more specific
Users browsing this forum: Bing [Bot] and 89 guests
