It is currently Sun Jul 20, 2025 11:40 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Fri Jul 10, 2009 8:35 pm
Mick wrote:
sgc wrote:
Off topic, but I wonder if this would be any good as a hydro pump.. :?:
I reckon you are a genius :!:
Out of stock, and ebay doesn't have them however...
It is listed as an "Air Grease Pump" but it is not an air pump, it is a manual one. But it should work as a hydro pump.
25bar = 362.59psi.
I was thinking of converting one of these...
To make the flashest and most expensive hydro pump in the world. I have one that I don't use much and it is almost going to waste.
Could you imagine just pulling the trigger and about ten seconds later the car is sitting on its belly in a pool of green liquid. :lol:
PostPosted: Fri Jul 10, 2009 8:40 pm
very interesting thread..... until it degenerated into hydro pumps - I've a mind to mod those out
PostPosted: Fri Jul 10, 2009 8:50 pm
Wombat wrote:
I was nearly going to buy a set on eBay - they ended up going for $57.65 with $20 shipping - just before it finished I saw the same thing here - FREE SHIPPING - NowI have a cheap set of panel beating tools :wink:
I'm going to buy a set of them....
but check this one out - dent puller kit
it's a hot glue gun, with a little bridge thingy that goes over the dent, and little feet that you glue to the dent. Thread the foot through the bridge and screw it down, and it pulls the dent up.
I've got a little ding in my roof that this would be ideal for - I'll make my own tho, hot glue guns are awesome
A body work artist (way beyond panel beater) I used to visit had the same thing but it welded itself to the centre of the dent and you pulled it up, then just ground the bit of weld off
PostPosted: Fri Jul 10, 2009 8:58 pm
Yep you can buy attachments for a Binzel MIG torch to weld studs on.
Would go well next to my/our carbon electrode MIG panel shrinking tool... :P
PostPosted: Fri Jul 10, 2009 10:00 pm
jeez, I forgot about that!! - I still can't use it because I haven't put in a 20A power point for my welder...
Users browsing this forum: No registered users and 72 guests
