It is currently Sun Jun 22, 2025 7:09 pm
PostPosted: Sun Jul 12, 2009 4:06 pm
for the brake booster? Saw a variety of angles today at the Mini50 show - even one pointed backwards and down (now I know that is not right), so what is a good upwards slope to allow proper bleeding?
David L
PostPosted: Sun Jul 12, 2009 5:15 pm
PBR VH44 booster can be level. Bleed nipple on top.
The old Lockleed one wants to point up a bit, bleed nipple at the end.
10° would do it.
PostPosted: Sun Jul 12, 2009 7:41 pm
PBR said that they only had to be at a slight nose up angle.
So anything would do. Fit it level and jack up the front to bleed it! :lol:
PostPosted: Sun Jul 12, 2009 7:46 pm
I thought the holes in the guard set the angle on the VH44?
Only a little is needed in any case..
 Post subject: Booster Position
PostPosted: Sun Jul 12, 2009 8:55 pm
Talked to Brooker brakes (Sydney) the other day about possible air in the system.
"Colin" was an old Mini guy for a long time ago. He was absolutely fabulous.
Advice ~
Air in the system:
Make sure the power booster has "its nose up a little" allows air to bleed.
Problem solving:
1. Clamp all four flex hoses and test pedal, should be hard
2. Release clamps one at time testing pedal each time. This will tell you which wheel has a problem.
SIMPLE. Hit my head on the post outside and though Doh.
"Boris" - '69 Cooper S Mk 2
