It is currently Sun Jul 20, 2025 8:43 pm
 Post subject: Heads
PostPosted: Fri Mar 04, 2005 4:15 pm
as mentioned on an earlier post of mine, i have two spare cylinder heads but don't know what the are off. how can i identify them easily ? anyone help ?
1977 Clubman
PostPosted: Fri Mar 04, 2005 4:24 pm
What number are on them :arrow:
PostPosted: Fri Mar 04, 2005 4:38 pm
Don't know, will have a look after work, what am i looking for ?
1977 Clubman
PostPosted: Fri Mar 04, 2005 4:46 pm
abcdefghijklmnopqrstuvwxyz1234567890
any combination of the above
:roll:
PostPosted: Fri Mar 04, 2005 4:50 pm
Yeh funny
what numbers mean what ?
1977 Clubman
PostPosted: Fri Mar 04, 2005 4:52 pm
you're looking for
12g202 or 12g295
anything else is just boring :)
http://drcwww.kub.nl/~bogaard/heads.htm
or there :)
PostPosted: Fri Mar 04, 2005 6:02 pm
Take off the rocker cover. Under there in all the crud is a number cast (not stamped) into the head.
For a Mini, could be-
12A1456
12G202
12G206
12G295
12G940
12G1316
CAM4180
12A185
AEG163
Let us know what you discover! 8)
PostPosted: Fri Mar 04, 2005 9:17 pm
Both are 12G202 So what are they, are they any good ?
1977 Clubman
PostPosted: Fri Mar 04, 2005 9:22 pm
They are 1098 heads- used on Morris 1100/Mini K/997 Cooper/1098 Clubbie. Inlet ports are square.
Not as good as a 295 head, but can be modified (with much work) to flow just as good or better.
Much better than the old 12A1456 (850 & 998) heads that had smaller inlet valves and ports.
PostPosted: Fri Mar 04, 2005 9:32 pm
Thanks
i have a 998 motor in my clubbie, so would it be worth cleaning one of the 12G202 heads up and installing, what performance improvements would i gain and if none how could i modify ? :?
1977 Clubman
PostPosted: Fri Mar 04, 2005 9:38 pm
sean wrote:
Thanks
If you clean it up and machine 1.5mm off it (as chambers are bigger than your old 998 head ones) it's worth around 4HP. I stuck one on my 998 `matic and it made quite a difference. 8)
<edit> For further increase, fit 998 Cooper inlet valves, recut the seats and port it to suit. Follow Vizard's book.
Of course then it needs a cam, bigger carbs, exhaust, yada yada... :wink:
PostPosted: Fri Mar 04, 2005 9:46 pm
What do you reckon it would cost to get 1.5mm milled off ?
1977 Clubman
PostPosted: Sat Mar 05, 2005 6:01 am
$50 I used to pay. Now I do my own.... :P
