It is currently Mon Aug 04, 2025 6:31 am
 Post subject: 998 crank
PostPosted: Wed Jul 15, 2009 10:25 pm
NAV-MAN
I've found out recently that the crank in NAV's 998 is rooted. A good mate has an A+ 998 kicking around he'll donate to me. Are the cranks interchangeable? If not what are the differences or changes needed to make it fit a non A+ block and gearbox?
 Post subject: Re: 998 crank
PostPosted: Wed Jul 15, 2009 10:36 pm
If your nice i will post you a 20 20 nitrided crank, good good.....
PostPosted: Wed Jul 15, 2009 10:46 pm
To answer your original question, yes the cranks are interchangeable.
PostPosted: Wed Jul 15, 2009 10:56 pm
gimme 200$ and I will wedge, grind and balance one of my spares, think it will only be 010 , 010 undersize
blokeinamoke wrote:
PostPosted: Wed Jul 15, 2009 11:03 pm
NAV-MAN
aaron wrote:
If your nice I will post you a 20 20 nitrided crank, good good.....
Really? Cheers Aaron. I love this Ausmini community, there is always someone willing to get behind another mini nutter and help. What would you like in exchange for it? I need a crank soon to NAV back on the road, and with any luck to the muster this year.
Is it a straight swap over if I use my existing primary gear?
Thanks for the offer. I'll get in touch if my other options fall through first.
PostPosted: Thu Jul 16, 2009 8:28 am
Is it a straight swap over if I use my existing primary gear? .
Yep :-)
PostPosted: Thu Jul 16, 2009 8:57 am
NAV-MAN
Yep :-)
I love it when there is a simple answer, Cheers Matt.
Users browsing this forum: Bing [Bot], timmy201 and 122 guests
