It is currently Mon Jul 21, 2025 6:16 am
PostPosted: Wed Jul 22, 2009 10:12 pm
NAV-MAN
I've been told by someone that you can remove or reduce the amount of built up carbon in the cylinder by spraying a fine mist of water into the engine while it's running.
I'm curious to know.
PostPosted: Wed Jul 22, 2009 10:15 pm
This is true, water injection has been around for years. Since I was a young 'un. :lol:
If you have a blown head gasket and water leaking in, or a crack in the head, that cylinder will have little or no carbon in the chamber.
PostPosted: Wed Jul 22, 2009 10:18 pm
So is it something you should do or not do?
Flute - 68 MK I Cooper S
Member: VMCI #2474
I would wonder how long would you need to apply water mist to the inlet to get a result?
PostPosted: Wed Jul 22, 2009 10:23 pm
I have also done this many times over the years using a spray bottle, it is amazing how well it works.
Have a Nice Day.
PostPosted: Wed Jul 22, 2009 10:25 pm
NAV-MAN
Works well enough to notice a difference in how the engine runs? or just how clean it becomes?
PostPosted: Wed Jul 22, 2009 10:36 pm
It does get rid of all the carbon & crap caught around the valves in the chamber & on top of the piston so i does bring a tied engine back to life for a little while & it can stop engine "run on" in old oil burners. Its more well known for its cooling & anti knock properies in Turbo engines.
Have a Nice Day.
PostPosted: Wed Jul 22, 2009 10:56 pm
yep how do you know the carbon is gone and is it just done on idle
PostPosted: Wed Jul 22, 2009 11:04 pm
This space for rent
Run the engine at 2500 - 3000 rpm and spray a mist of water into the carb mouth. It'll belch steam and black soot for a while, when this stops you've cleaned most of the crap out ;)
PostPosted: Wed Jul 22, 2009 11:38 pm
Yeah i think i remember warrick Augustin saying this one time.
But by memory too much and you will brake your motor.
PostPosted: Thu Jul 23, 2009 5:34 am
I am definitely trying this when I get home.
Didn't Spitfires have water injection in their V12 Merlins?
PostPosted: Thu Jul 23, 2009 9:01 am
I have tried this too on an old Bluebird that was pinging its ring off. The carbon deposits in the cylinder get hot and cause pre ignition. Worked well, did another 20k with no issues.
PostPosted: Thu Jul 23, 2009 10:13 am
It does work. Remember that you want a fine spray, a mist entering the carby intake while the engine is running at normal temperature.
Pouring water into the intake = bad
PostPosted: Thu Jul 23, 2009 2:47 pm
Its basically just like steam cleaning.
Great to stop pinging on forced induction engines.
PostPosted: Thu Jul 23, 2009 3:40 pm
isn't that because it's cooling the piston and combustion chamber, rather than removing carbon deposits?
I'd do it on a motor I didn't care about, on a motor I cared about I'd just take the head off.... I don't like the idea of chunks of hard stuff bashing about in my cylinders :?
