It is currently Thu Jul 24, 2025 11:59 am
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 62, 63, 64, 65, 66, 67, 68 ... 568  Next
PostPosted: Fri Jul 31, 2009 12:50 am
put in a ciggy lighter socket,so i can run my radar detecter,thought i could drive faster because of it,turns out it is really sensitive,so makes me drive to too the speed limit,all good im thinking
First you get the money,then you get the power,then you get the Mini.
PostPosted: Fri Jul 31, 2009 9:02 pm
Put my mini on a tow truck this morning and sent her to town :D ! Shes goin in for her overhaul ( gettin ridda rust, new paint, the worx at the mo :roll: !) Am very excited! Will post as progress happens!
Cheers, Kim :-)
**purple '68 deluxe!**
***FINALLY wearing number plates----yeaaaaaah baby! ***
PostPosted: Fri Jul 31, 2009 9:55 pm
Had to make mine look respectable as we might have mini visitors on the weekend
PostPosted: Fri Jul 31, 2009 10:01 pm
And why arn't you still out thier :roll: :lol:
PostPosted: Fri Jul 31, 2009 10:06 pm
Its Vert cold Gamf, Very Very cold, foggy an down right nasty, but the two girls are clean, happy an warm in their lil blankys :lol:
PostPosted: Sat Aug 01, 2009 12:12 am
Picked it up from its post-electronic-ignition tune. :D Very happy that the new road near my place has cut 15 minutes :shock: of travel time off the trip to Mini Auto. Makes it a very, very short trip. Even shorter picking it up, because it's running very nicely. 8)
PostPosted: Sat Aug 01, 2009 4:03 pm
since collecting my 'new' wheels last week i have found every reason under the sun to take it out for a blast..... :)
PostPosted: Sat Aug 01, 2009 11:10 pm
Pic's of the new wheels Please 8)
Started to Bling the 1 1/2 carb :lol:
PostPosted: Sat Aug 01, 2009 11:54 pm
Finished off the bottom rail of the drivers door frame and gave it a coat of cold gal paint
David L
PostPosted: Sun Aug 02, 2009 12:38 pm
will hopefully get to pick it up today and drive it for the first time in 2 months!
gtbbh.
tim
PostPosted: Sun Aug 02, 2009 1:15 pm
This space for rent
superSeven wrote:
gtbbh.
Welcome back 8)
PostPosted: Sun Aug 02, 2009 1:36 pm
Milatsmadmini
have to replace a bearing.... again.... :roll:
i guess it will give me a chance to take off the old drums put some new ones on with new pads, lines and maybe springs?
PostPosted: Sun Aug 02, 2009 3:03 pm
New rear wheel bearing :cry:
New knuckle joints even though they werent as bad as I was told :roll:
Look and look and look for stupid brake creaking noise :? that went away anyhow
New Hydro pump up to a nice level with no air this time :D
Best its ever driven :)
PostPosted: Sun Aug 02, 2009 5:38 pm
Welded on my van... sheetmetal welding for the first time ever. Pleased with my efforts.
PostPosted: Sun Aug 02, 2009 5:43 pm
Etch primed the drivers door frame around the edge where the skin will go.
Tackled the passenger door bog. The door had at some stage been bent back on the hinges and points of the hinges had made big dents in the door skin. The bog around the bottom hinge was so deep I was able to chisel it off with a hammer and screw driver :shock: - 1/8" to 1/4" thick. The top hinge was nearly the same but not as big an area.
Took all of 5 minutes to knock out the top hinge dent and get it 99% smooth (one bit about the size of a 10c piece I can't get behind cause the frame is in the way.)
Bottom took a bit longer got most of it out but for a bit about the size of a 20c bit just to the rear of the inner most hinge bolt hole - it's over the frame piece and there is a spot weld right in the middle - I can't get behind it with a hammer because the door pocket is in the way.
I'll try the heat then freeze technique on it and see what that does - if that doesn't work then may have to put up with a little bit of bog. :roll:
David L
Users browsing this forum: Goldbrocade_62 and 105 guests
