It is currently Thu Jun 26, 2025 6:27 pm
Post new topic Reply to topic  [ 117 posts ]  Go to page Previous  1 ... 3, 4, 5, 6, 7, 8  Next
PostPosted: Thu Jul 30, 2009 8:43 am
pubudug wrote:
on the topic of these gearboxes with reverse, why cant we use a normal gearbox off a small FWD car like a CB70 gearbox or a
We can select the particular gear we cant, get rid of all the other gears, machine the bell housing etc etc to get rid of the excess weight. Put in the diff we want and ready to go.
Just curious as to how much a 4efte gearbox weighs? Some of those reversible gearboxes not not feather light either..
Mainly because we want 5- or 6-speed sequential gearboxes which allow us clutchless gearchanges in less than half a second!! :shock:
If you have ever driven one ( a road car or race car with a sequential, dog-engagement gearbox) they are just freaking awesome!
Spending a month or so nutting out how I can get a reverse in there that the ginger-beer will approve, is a very small price to pay!!!!
I think Matt et al will agree with me......
Tricky
PostPosted: Thu Jul 30, 2009 12:45 pm
I totally agree with you there mate,
my idea doesn't involve using the car clutch.. its completely taken off and the driven sprocket installed directly to the layshaft of the gearbox.
This way we can get rid all the other forward gears and reduce size, weight of the unit.
You would only have essentially 2 gears, one forward and one reverse. you would have to come to neutral on the bike gearbox and the car has to stationary and you flick it to reverse and then i suppose you got 6 reverse gears! you will still use the bike clutch, hence we still got sequential shift
PostPosted: Thu Jul 30, 2009 1:39 pm
I had a similar thought but wouldn't use a manual box, the guts of an auto may well yield sufficient epicyclic gear sets and clutches to have a straight through box with forward and reverse. With a straight through arrangment, there would be no power loss in forward.
You'd need to make a box to hold all the bits together. That is the expensive part.
Anyone got a drawing of the guts of say a commodore auto?
M
PostPosted: Thu Jul 30, 2009 3:23 pm
I guess you are planning on a front engine RWD so commodore would be ok.
I want a FWD gearbox since I am going the mid mounted route. the casing can be reused, otherwise you might as just buy one of those custom made boxes and save yourself the trouble
PostPosted: Thu Jul 30, 2009 3:32 pm
All plausible solutions I am sure.
The way Matt and I have been thinking about reverse, is we will use a car starter motor directly coupled to the primary output cog on the gearbox, via a flexible coupling and one way bearing, or flexible coupling and magnetic coupling (similar to A/C condensor).
So, by using neutral as an electrical lockout, the magnietic coupling and power to the motor would not be engaged until neutral was activated. Once activated, you push a button on the dash to engage the motor and coupling and voila, reverse!!
This should leave everything nice and compact with no complicatiions around the diff area.
PostPosted: Thu Jul 30, 2009 4:17 pm
electrical lockout mech should be on set up the clutch lever,,, that way we can do reverse motorkhana events leaving the bike engine in gear, ready to take off once the reverse bit is over & done with, , no stuffing around engaging gears in the middle of a front throw or reverse flick
Edit--> & no, we`re sorting ours out as a rear/mid engine layout,,, east-west
Maybe if/when we`re rich enough we might look at ordering one of those sooper yoo-beauty mech revers boxes with slippery diff already inside
PostPosted: Thu Jul 30, 2009 5:14 pm
Why not use a prop shaft bike setup like from a BMW and connect it to a diff?
PostPosted: Thu Jul 30, 2009 6:51 pm
is this going to be a track weapon or street legal?
PostPosted: Thu Jul 30, 2009 8:24 pm
A street-legal track weapon! 8)
PostPosted: Sat Aug 01, 2009 9:21 pm
Are you planning on running a diff or a spool in the back of it?
Im really interested in this, basically a big version of what we make in the uni motorsport team.
Simplify and add lightness
PostPosted: Sun Aug 02, 2009 1:22 am
Basically running a full chain drive LSD in the back with inboard discs.
Most likely a diff from Quaiffe or TRE,
Price will dictate the eventual outcome I would think.
Trciky and Matt.
PostPosted: Sun Aug 02, 2009 9:47 am
Archangel007 wrote:
Trciky and Matt.
hee hee,,, i like that trickster :-)
PostPosted: Tue Aug 04, 2009 7:57 pm
I've been chatting with the engineer some more and it seems like the mechanical reverse gear rule can be bent somewhat. We should be able to get away with an electric starter motor. He said all requirements state is that the driver has to be able to engage reverse in normal position while engine is running.
This can be achieved with a starter motor
He told me to check out how the aussie race cars do the reserve in their machines.. assuming they have reverse gear?
Tricky/Matt, you guys would know about this I suppose? I am not into motor sport at all :oops:
PostPosted: Sat Aug 08, 2009 10:37 am
here's a little something from the eastern most state of australia.....
http://www.oldschool.co.nz/phpbb/viewto ... 17&t=17181
food for thought...!?
PostPosted: Sat Aug 08, 2009 1:05 pm
niceeee....
I think a lot of people are doing similar things for engine at front RWD projects. I still want to see someone have a go with the fwd gearbox and use a chain drive..
maybe it will be too big to fit it at the back... maybe
