It is currently Sat Jun 21, 2025 5:35 am
 Post subject: door trims
PostPosted: Sat Aug 08, 2009 7:18 pm
I pulled out the door trims from the woody today and the cardboard backing is not good what do you suggest as a replacement or to firm the original up . They are 850 type trims
PostPosted: Sat Aug 08, 2009 7:24 pm
Have a look at this stuff, people have used this before and it does the job, scroll down to the Laminated Sheet.
http://www.corex.net.au/PRODUCTS/ExtrudedSheetProducts/Corflute-Fluteboard.aspx
PostPosted: Sun Aug 09, 2009 5:39 pm
Thanks for that , any other suggestions?
PostPosted: Sun Aug 09, 2009 5:45 pm
The original upholstery card can be purchased in sheets from upholstery suppliers such as Daleys AMU out at Parramatta.
I've used it a number of times and find it nice enough to use.
PostPosted: Sun Aug 09, 2009 10:44 pm
I'm Bert , where's Ernie
trimboard from daleys next to villawood, i've used 3mm mdf for my door panel.
'73 clubby s "cryo" - sold
Operation Evil Sesame Street!
PostPosted: Mon Aug 10, 2009 9:28 am
I do hope you sealed the back with fibreglass resin or something. Otherwise if/when it gets wet, it will revert to being tree-shaped. :lol:
PostPosted: Mon Aug 10, 2009 11:24 am
sure did, hard as a rock once it cured :D
