It is currently Sat Jul 26, 2025 9:52 pm
PostPosted: Thu Aug 13, 2009 1:40 pm
On a rover the front mounts have two bolts. One goes from subframe to rubber block, and another from rubber block to body.
PostPosted: Thu Aug 13, 2009 3:59 pm
VicMini13 wrote:
Early Minis (including all Oz built) have a metal "teardrop" shaped "mount" that fits between the front of the subframe and the body - bolted to both.
I don't belive any oz minis or pre-1975 UK minis had any mount on the front of the subframe, just plain 5/16 bolts bolting the frame to the body.
Andrew
PostPosted: Thu Aug 13, 2009 5:24 pm
Andrew
No Oz Mini 1961-1978 ever had a teardrop mount at the front ex-factory. But some cars that have since had a shunt and a late UK front panel fitted, have a teardrop mount or spacer there.
PostPosted: Thu Aug 13, 2009 6:24 pm
I see, the cars ive stripped were a 65 deluxe and a 72 clubby. Had me a bit worried as i have no recollection of these mounts.
Simplify and add lightness
