It is currently Mon Jul 21, 2025 12:35 am
 Post subject: Here's a trick
PostPosted: Tue Mar 08, 2005 7:09 pm
In the old days when all cars leaked oil we used to wrap the engine mounts in plastic to save them getting buggered by oil. Just a thought.
Chris
Everything I like is either
PostPosted: Tue Mar 08, 2005 8:00 pm
does it actually work
have u done it before
thats not a bad idea if it works cos i had to change one of my engine mounts
(with engine in car) and it is not the easiest thing to do, very fidgity :cry:
but not to worry i did it :wink: :D
Nigel Morton/ Team Brickworx
never late in a 998
PostPosted: Tue Mar 08, 2005 9:33 pm
Is this because the oil eats away at the rubber in the engine mounts?
dwightgunning.com
PostPosted: Tue Mar 08, 2005 9:36 pm
Thats correct.
Motor oil etches natural rubber.
This is why you should use "rubber grease" when greasing rubber parts.
Quite simple when you think about it :)
PostPosted: Tue Mar 08, 2005 10:42 pm
if you buy replacement engine mount rubber kits now, they are actually red polyurathane I think. not rubber anyway.
I doubt they will be effected by oil. About $12 a set (4) from Repco does one engine mount.
edit: I thought you were talking about the top engine mounts, but I just realise you may have meant bottom mounts.. I know nothing about them ;)
www.crazybitchracing.com
PostPosted: Wed Mar 09, 2005 2:46 am
big willy wrote:
Thats correct.
Greasing rubber parts? Try some KY :wink:
PostPosted: Wed Mar 09, 2005 10:20 am
I wonder if you can buy poly engine mounts. They would be the ultimate answer. Be bloody stiff though.
Chris
PostPosted: Wed Mar 09, 2005 11:18 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
then you really would need KY
makka
PostPosted: Wed Mar 09, 2005 11:29 am
you can buy them, they're in miniworld etc. look pretty cool, they're yellow, and are in 2 pieces you put a pin through them. half goes on the subframe and half on the engine, they slot together when you drop the motor in....
