It is currently Mon Jul 21, 2025 12:21 am
Post new topic Reply to topic  [ 20 posts ]  Go to page Previous  1, 2
PostPosted: Wed Mar 09, 2005 7:01 pm
Chris wrote:
Stuartminidlx wrote:
It is advisable that gearboxes fitted with this attachment be removed regularly to ensure that no excessive build up of sludge has built up around the gauze mesh. quote from
[/url]www.minimania.com[url]
thats all i know on the subject
Stuart, can you link to the exact page please.
2 things..
1. I would change oil often, mine gets done every 1500miles and never had sludge.
2. Extended magnet on sump plug (from MiniSpares etc) is a good idea. :wink:
PostPosted: Thu Mar 10, 2005 8:02 am
:shock:
Chris,
I had one in my car for over 30K miles without any problems. Moved it to another gearbox and it was as clean as the day it went in. If you live in Pommgolia and don't change the oil or indulge in circuit racing and do bad gear changes it might be an issue but in OZ for everyday use - no problem.
If you don't already have one be aware that the early ones will only fit 3 synchro boxes. The later ones will fit both 3&4 synchro boxes.
Regards
RonR
PostPosted: Thu Mar 10, 2005 2:32 pm
Thanks for the info Ron. I can tell a good story about sludge. A bloke who used to get his EFI Cressida serviced religously (it did taxi type mileage) brought his car in one day to my workshop to see why the bearings were rattling. We got the motor out and the sump off and pulled sludge out of it by the handful. These motors had a reputation for it apparently due to how lean they ran....so we were told.
Chris
Everything I like is either
PostPosted: Thu Mar 10, 2005 5:11 pm
the adress is way to long and i couldn't get it to work so u will have to copy and paste it http://www.minimania.com/web/DisplayID/56/SCatagory/GEARBOXES/DisplayType/Technical%20Information/CarType//ArticleV.cfm
FOR SALE MInidlx, 1293, GR head, RE-13, GR worked Redline Manifold, 45 mm DCOE,pulsar dizzy , "S" Disc's, Mk II "S" box, 3.65 diff. Minator 10X6's On the loose
yay it worked
Users browsing this forum: Majestic-12 [Bot] and 79 guests
