It is currently Mon Jul 21, 2025 12:16 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
PostPosted: Tue Mar 08, 2005 10:32 pm
Save Pennies and Go Alloy
Wider / Bling factor - Good painted or Polished
A lot to choise from and Differnt Sizes 8)
PostPosted: Wed Mar 09, 2005 2:19 pm
They do look rat sh*t but the sand blasting will hopefully get it off but I know for a fact that they are 4.5 inch wheels because I measured them personally and I can get a ruler on them and take a pic if there are any other people that say so because 3.5 do sound a little thin too I agree with JAM but I will take what everyone said and ask my dad but they will be getting powdercoated, I will be getting the to not powdercoat the wheel nut holes but apart from one or two suggestions I haven't really gotten a straight answer
_______________________________________________
Team MADMAN/Pat Rogers
PostPosted: Wed Mar 09, 2005 2:45 pm
or you could get wide steelies ;)
PostPosted: Wed Mar 09, 2005 3:45 pm
gotta measure between the beads, not all the way across the rim - they're 3.5 unless they're widened... and if they're widened they're usually 5" or 6"
PostPosted: Wed Mar 09, 2005 7:16 pm
Well there are a set of 10x 4.5 jelly beans on the clubbie we have and it says an the side of the rim "10x4.5" and these steelies are the same width as them cause I took a wheel of the clubbie and it lines up with the steelie
Explain?
Pat
PostPosted: Wed Mar 09, 2005 7:20 pm
The Clubbie 4.5s are widened inwards. Outer part of rim is in same spot as a 3.5 is.
Ditto for an S wheel. :wink:
PostPosted: Wed Mar 09, 2005 7:42 pm
So what you are saying is that there is the same amount of tread on the road but it is just the inside of the rims that is different
Big whoop they have more tread on the road then my 12 x 5 inch rims do
pat
