It is currently Thu Jun 19, 2025 9:20 pm
Post new topic Reply to topic  [ 193 posts ]  Go to page Previous  1 ... 8, 9, 10, 11, 12, 13  Next
PostPosted: Wed Aug 19, 2009 2:00 pm
Mini Porn!
PostPosted: Wed Aug 19, 2009 2:17 pm
GR wrote:
This photo is showing the centre exhaust and the route it has to take to get out on the original 8-Port Head
It's not as bad as it looks as it flows quite well.
This is the 7 Port for comparison:
NOW I understand why a 7 port instead of an 8 port - so does the 7 port work better than the 8 port because of that, or are there other reasons?
PostPosted: Wed Aug 19, 2009 2:55 pm
This space for rent
In addition to this question, how well does the 7 port scavenge vs the 8 port? Is it easier, harder (or impossible) to tune the exhaust harmonics with the siamesed central exhaust?
Seriously looking forward to seeing the results of one of these on your engine dyno :twisted:
PostPosted: Wed Aug 19, 2009 4:19 pm
GR,
Isnt the maxium capacity aloud under the CAMS rules for catagoy 5 in NC 1330 not 1360...
1275 plus 060. equal less than 1360ccc
1.5mm max
Just curious thats all ?
PG
Engine:
(i) Reciprocating engines: The bore may be increased by a maximum of 1.5mm, and the stroke must remain
standard as specified for the make and model.
Where increasing the bore size up to 1.5mm increases the engine cubic capacity above the original
capacity class limit, for competition purposes the vehicle will remain within its original cubic capacity
class.
Toothed belts driving engine ancillaries are permitted. Engine pulleys are free.
1964 Grp Nb Cooper S
1976 911 3.6 Circuit Car
1969 911T Grp Sb Historic Racer
2009 LC200 V8 TDI.... 660nm..
2011 Golf VI, TSI
PostPosted: Wed Aug 19, 2009 7:40 pm
Oh dear, worry, worry...
Hi Simon and Simon
The 7 port layout was designed so you can use the std cam and
and the std exhaust manifold to cut costs down with the conversion
The siamese exhaust port does flow better than the 8 port.
You can still tune your exhaust as with the 8 port because you still
have 4 inlet ports and the centre exhaust being siamese to cyl 3
and 4 still dont exhaust at the same time so theres not really a
problem, personally ill take 7 port over the 8 port.
Graham Russell
PostPosted: Wed Aug 19, 2009 7:52 pm
High heel ninja
girtp wrote:
GR,
1.5mm max
PG
Engine:
class.
All Gr's race engines are 1330, the 1360 is being used as another example.
Doogie
PS, kettle on Graham?
PostPosted: Wed Aug 19, 2009 8:10 pm
Hi Paul
Yes your right i was thinking plus 60 and typed 1360, do i have beg
for forgivness? its not my first mistake and it sure won,t be my last
one, if only you knew how long it takes me to type this thing out
my fingers are about 3 lines behind my brain then they start to
FIGHT
the key board gets the sh--s then i wind up with a hell of a mess
and have to start again or call josh or aaron(he lives closer now)
but josh came round for lunch so he posted the photos for me and
set it all out, see what a cupa can do.
Graham Russell
PostPosted: Thu Aug 20, 2009 7:46 am
GR,
No forgivness required, just want to check I wasn't missing out on that extra 30cc's........
PG
2011 Golf VI, TSI
PostPosted: Fri Sep 04, 2009 1:27 pm
How much development is there on the camshafts for 7 & 8 port heads? Are they very different from the 5 port cams to get the benefit of 4 inlet ports as opposed to 2?
2008 Prado GXL
PostPosted: Fri Sep 04, 2009 3:56 pm
This space for rent
Dave, the 7 port head uses the standard cam used in the 5-porter -- that's the attraction of the 7-port over the 8-port, it's way cheaper as you don't need a special cam grind (and you can use your normal extractors, too).
PostPosted: Fri Sep 04, 2009 4:10 pm
true, but the 7 port head might allow for more aggressive valve overlap etc. given the engine doesn't have to deal with siamese ports etc. etc.
maybe... :)
PostPosted: Fri Sep 04, 2009 5:05 pm
That was more the angle my thinking was going.
2008 Prado GXL
PostPosted: Fri Sep 04, 2009 5:15 pm
This space for rent
I don't think it'll make any difference, the two valves exhausting into the siamesed port on a 5-porter are 360º apart, so the pulses are spaced far enough apart that cam timing shouldn't come into it. I think.
PostPosted: Fri Sep 04, 2009 5:23 pm
He's talking about it relative to a 5 port- there's no charge robbing in the inlet ports so you can perhaps use more agressive duration and overlap.
PostPosted: Fri Sep 04, 2009 5:51 pm
When i dropped down for a cuppa, GR was bouncing off the walls, He was playing cams, specifically cams for 7 ports....
funny how he's on it and someone asks the Q.
I didn't even get a cuppa... He must have been excited by it.
