It is currently Wed Jul 23, 2025 8:26 am
PostPosted: Sun Sep 06, 2009 4:39 pm
Should i be happy that i found a good double row timing chain??
This is no-4 crank bearing, reckon i just caught it in time
All the lifters are like this except 2 but the cam looks as new
This is my biggest worry, cos she was sitting for so many years corrosion has eaten into the block face, Will a deck fix this?
2& 3 bores are like this so i guess a rebore is in order, i gave no-2 a quick hone but corrosion marks are still there
Rusty crank journals. Dont you hate it when good things are neglected!!
The block worries me as i cant get another block as numbers will be all out. I know i can buy a rebuild kit online for around$450(minisport) does any one know a ballparkish figure to get the rest sorted,block decked, rebore,crank grind ect, im trying to work out a budget that wont freak the wife out :lol:
PostPosted: Sun Sep 06, 2009 4:43 pm
Tomboss Breweros
Block will machine up good.
Just send the bits to a good re-con shop and it will come back all good, it's amazing what they can do.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Sep 06, 2009 4:45 pm
Tomboss Breweros
cam bearings prob not too flash either.
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Sep 06, 2009 4:47 pm
Thanx tombo, i feel marginally better now, do you reckon the cost will fu*k me in the blurter :shock:
PostPosted: Sun Sep 06, 2009 4:50 pm
Is this the LS Maxx ? If so be very clear with whoever decks the block that it is a matching number classic carand the engine number has to remain untouched while they skim the top of the block . It is possible to do and you should check with them if their machine can do it that way before letting them do the job .
PostPosted: Sun Sep 06, 2009 5:20 pm
Tomboss Breweros
Through the trade a rebore and face, crank grind crack test and balance, cam grind and bearings cost me $700
Bit worried bout those funny looking cracks :roll:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Sep 06, 2009 5:22 pm
Online
Get that 1275LS crank crack tested before grinding. Many are cracked... :cry:
PostPosted: Sun Sep 06, 2009 5:25 pm
Tomboss Breweros
Make sure they keep that nice radius on the crank journals 8)
kimini wrote:
Jimmyinamini wrote:
PostPosted: Sun Sep 06, 2009 5:32 pm
That would be cat hair, its everywhere here, even i get hairballs :shock:
PostPosted: Sun Sep 06, 2009 5:35 pm
Yes it is the LS Sports, thanx for that regarding the engine number, i never thought ov that. I will stress that point profusely
PostPosted: Sun Sep 06, 2009 8:33 pm
I was wondering why you were pulling the engine out :shock:
Crack test that crank and balance it with the fly wheel and clutch assembly once its been cleaned up.
Block yep will need to be cleaned up to the next size (if not the followiing)to you will need new piston and rings. Check that the rods are the same weight and straight.
Get some one who knows what they are doing to put it together corretly :wink:
Make sure the numbers on the block are saved
All will be Good 8)
Users browsing this forum: drmini in aust and 86 guests
