It is currently Sun Jul 20, 2025 10:45 pm
Post new topic Reply to topic  [ 44 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: re diagnosis
PostPosted: Tue Sep 08, 2009 8:09 pm
hi guys dont despair too much with rover diagnosis issues and most parts in victoria, as we do have a diagnosis computer with the tune up facility availiable for use by selected mini workshops(we only sell the parts) and there are a few others who have efi bits availiable.
cheers josh
miniimports
PostPosted: Tue Sep 08, 2009 9:39 pm
bnicho wrote:
..... For example the ECU in Japan spec is different to UK spec........
There are only two ecu's for a SPI, the standard one for the 50hpmptor with 9.1:1 comp ratio and the cooper one for 60hp with 10.1:1 comp ratio and that covers both the english and Jap specs.
Cheers Pete
PostPosted: Tue Sep 08, 2009 10:03 pm
Cheers Pete
The Jap spec ECU for the late SPi coil pack engines (no dizzy, basically an MPi block) in the 1997-2000 cars are unique. They have a different part number to the other computers and do not incorporate an immobiliser.
Josh, good to know you have the diagnostic equipment. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Wed Sep 09, 2009 1:03 am
Super-mini wrote:
i believe that means no UK minis. Jap only '97-'00
I did see that, but one can only ask - it's always possible there's more info than is on the website. Progress not yet disclosed... And aren't there fewer differences between the pre-96 UK and JDM cars? So, if you could get a pre-96 (i.e. SPi, no airbag) JDM car complied, wouldn't it be similar to get a UK car complied? :? One can only ask such things... :wink:
PostPosted: Wed Sep 09, 2009 9:30 am
If only it allowed the importing of Hybusas.... oh how i want one of them..!!!! :)
PostPosted: Wed Sep 09, 2009 10:12 am
Diagnostics shouldn't be too hard as OZCOOPER said he's got the gear. But you can probably get some of the gear too.
My dad does all his diagnostics for his TD5 Discovery himself. Not really to find faults more or less to clear ones that don't exist. But he can either plug the laptop in and have a proper go or use his little hand held one and reset faults, read off faults etc etc...
PostPosted: Wed Sep 09, 2009 8:15 pm
Oop's Sorry forgot about the coil pack ones.
I think you will find a few of us on here have the diagnostic equipment, I am one of them.
cheers Pete
PostPosted: Thu Sep 10, 2009 9:25 am
I tried awhile ago to find someone who could do a diagnostic on my 97 Spi... with no reply....
originally Brickworx said i could send the computer to them and they could install it on one of their cars so they could fault find and fix.
Does anyone know if there is someone who can do this? I live in QLD.
She still sometimes likes to rev low when coming to a stop (e.g. at traffic lights she likes to drop to 500rpm)
thanks
Deb
PostPosted: Thu Sep 10, 2009 5:20 pm
Do some searching on eBay. Dad got his gear from there. Someone was making portable fault find and diagnostic setups for various British cars a while ago, they were fairly well priced too. Alternatively you can also search for a a diagnostic program that does it (in fact the computer program that dad has might do it but not sure, I've never used it).
PostPosted: Thu Sep 10, 2009 8:12 pm
thanks
Deb
These are the items that you need.
You can some times get the handsets cheaper just keep an eye out.
Cheers Pete
Handset
cable
Pod
PostPosted: Thu Sep 10, 2009 9:01 pm
Rover Cooper
So after all that chit chat, where in Victoria can you take your car to have the puter thingie connected to check out the system, please.... :wink: :wink: :wink: :wink: :wink:
PostPosted: Fri Sep 11, 2009 8:34 am
wow they arent cheap are they! thanks for the links Deluxe, was thinking of getting one but then choked at the price of the handheld then you still need the cheaper pod and harness :cry:
Used to have 2000 Cooper Classic Sport 500, No 338, currently miniless :(
PostPosted: Fri Sep 11, 2009 8:53 am
Id say theyre not too expensive, compared to what they do. Beats getting charged that every time you pay someone to do it for you.
Simplify and add lightness
PostPosted: Fri Sep 11, 2009 9:37 am
or someone could buy it and "rent it" to fellow Ausminiers who need it.... say $25 per time plus postage???
PostPosted: Fri Sep 11, 2009 12:58 pm
yeah true. i could do with getting it then starting Stews MPI Diagnostic Services :D
Users browsing this forum: IndigoBlueCooperS and 70 guests
