It is currently Tue Aug 19, 2025 3:06 am
PostPosted: Tue Sep 08, 2009 10:34 pm
oh ok well yeh i might get one of them when i save some money. But until then i might just stick with a Lucas one.
PostPosted: Wed Sep 09, 2009 4:33 pm
Just get one from a wrecker. Mine was only $45.
PostPosted: Wed Sep 09, 2009 7:00 pm
I love the working su, thats cool
this is why they are so adaptable, the damper will only lift to give level of air flow that the engine needs. this is why the correct needle is so critical.
PostPosted: Wed Sep 09, 2009 9:27 pm
Hey,
Just wondering when your looking at the engine is it 1-2-3-4 (it terms of the plugs etc.) left to right?
Thanks Blake
PostPosted: Wed Sep 09, 2009 9:29 pm
4-3-2-1, 1 is closest to the radiator
PostPosted: Wed Sep 09, 2009 9:43 pm
riteo then i thought it was wierd the leads werent long enough but yeh thanks
PostPosted: Mon Sep 14, 2009 11:37 am
hi,
i was just wondering if the MG Spares where you can get the starter motors from, is that http://www.mgspares.com.au/?
Thanks Blake
PostPosted: Mon Sep 14, 2009 11:48 am
Take a look at this link, the mini businesses are listed state by state. Any of the guys in the listing should be able to help you with a new starter motor, there's a couple listed for minis in the ACT although courier shouldn't cost that much if the price is competitive from Interstate..
The link is permanently at the top of the page in the How To room.
http://www.ausmini.com/forums/viewtopic.php?t=10543
PostPosted: Mon Sep 14, 2009 2:09 pm
This is the one Blake:
http://www.mgspareparts.com.au/index.ph ... &Itemid=26
$152.35 + add $15 postage to Canberra.
:wink:
PostPosted: Mon Sep 14, 2009 8:11 pm
Thanks i think i'll get that one.
Another question (sorry im asking so many questions) the spacer between the manifold and the SU, does this do anything? I notice it allows the throttle to clear but m i able to bend the throttle bit a little to clear?
Thanks Blake
PostPosted: Mon Sep 14, 2009 8:14 pm
It adds volume and length to the manifold, which increases torque...
On Cooper manifolds with twin SUs, I use 2 spacers on each carby. :wink:
PostPosted: Mon Sep 14, 2009 8:16 pm
mmmm ok then well i better get one ( if i can find one or two anywhere) are they 10mm thick?
Blake
PostPosted: Mon Sep 14, 2009 8:19 pm
That link describes a pre-engaged starter, but the part number is for a standard inertia type starter....just be sure you know what you're getting exactly to save on the return post.....
Mick
PostPosted: Mon Sep 14, 2009 8:42 pm
HMG815 starter in that link is the correct one. It's a Gemini copy (made in China...)
It bolts straight into an Oz Mini. Holes are already slotted. :wink:
PostPosted: Tue Sep 15, 2009 9:19 am
Yeh, It's a little confusing Mick - the description has "REP LRS102" Which means it "Replaces" the origininal inertia type "LRS102".
Users browsing this forum: Bing [Bot] and 262 guests
