It is currently Sat Jul 19, 2025 7:34 pm
PostPosted: Wed Oct 07, 2009 10:20 pm
Just wondering if it is more cost effective to just buy a length of rubber and locking strip rather than buying the individual packs from a supplier?!
Also be good to know a good supply for it and the type/profile?! lol
PostPosted: Thu Oct 08, 2009 12:16 am
Novus stoc the strips but id be a bit hesitant about using a long piece of rubber as i reckon you may have probs getting the two ends to seal up as they shrink over time.... well thats my opinion any hoo :wink:
PostPosted: Thu Oct 08, 2009 3:39 pm
Tomboss Breweros
I used rare spares for mine, already in a loop so no gaps.
Also they are a wide rubber so its easier to hide where trims are glued to the body :wink:
kimini wrote:
Jimmyinamini wrote:
PostPosted: Thu Oct 08, 2009 3:41 pm
I buy the proper windscreen ones and they fit OK. No leaks.
Last time I did the rear, I bought a MK2 (UK) rear one and cut it. Too short...
This time I bought a MK1 rear one (UK made) from MiniKing. I still had to cut it about 50mm. :cry:
There was no way it was going to fit otherwise. We tried for about 2 hours. I may as well have bought it by the metre from Grippy Rubber or somewhere.
PostPosted: Thu Oct 08, 2009 4:27 pm
This space for rent
Interesting, I just bought a UK Mk1 windscreen rubber from Mini Spares, and it fit perfectly.
PostPosted: Thu Oct 08, 2009 4:31 pm
My mate 4myego bought the same rear one I did from Mini King, his fitted OK.
And, he helped fit mine, what a bastard job it was. He agrees...
Note- my rear window aperture has a slight twist, the result of a rear shunt some time in the distant past.
I have heard of others having to cut UK Mk1 rear rubbers. The length must be inconsistent before they glue em together.
Last edited by drmini in aust on Thu Oct 08, 2009 4:32 pm, edited 1 time in total.
PostPosted: Thu Oct 08, 2009 4:32 pm
Must be the climate differences between vic and NSW :lol:
PostPosted: Thu Oct 08, 2009 8:34 pm
uk mini's have larger rear windows don't they?(later models)
PostPosted: Thu Oct 08, 2009 8:42 pm
yeah but their Mk1s are same as ours.
