It is currently Fri Aug 15, 2025 3:34 pm
Post new topic Reply to topic  [ 8519 posts ]  Go to page Previous  1 ... 87, 88, 89, 90, 91, 92, 93 ... 568  Next
PostPosted: Fri Oct 09, 2009 2:21 pm
Changed the front brake backing plates from single leading shoe ones (I can't get parts at the moment for them :cry: :cry: :cry: ) to twin leading shoe ones . Couldn't get the #$@$%#W$% brake hoses off the subframe so left them on . Master cylinder kit hasn't arrived yet either so have new brake parts on the front but no fluid in them or no master cylinder on the car :(
Also fitted the rear mat I got from mini king a couple of years ago and gave it all a damn good wash :D
Feels great to be getting the hands dirty on it again 8)
PostPosted: Fri Oct 09, 2009 2:29 pm
But washing a car is getting your hands clean! :lol:
PostPosted: Fri Oct 09, 2009 2:32 pm
picked it up and bought it home
'62 Morris 850 (Marion)
'69 Vanden Plas Princess 1300
'71 Wolseley 1300
'74 Austin 1300 Countryman
'94 XJ6 Sport 3.2
'04 Rover 75 CDTi
PostPosted: Fri Oct 09, 2009 2:37 pm
It still didn't wash all the grease and crud off from changing the brake backing plates though young Harley ...
PostPosted: Fri Oct 09, 2009 2:42 pm
Good to see you working on the car Ian. I have been stuffing around with adjustments on the mecahincal brake switch. The pressure switch used to cause the brake lights to never come on unless the brakes were slammed on, now the mechanical switch is causing them to never go off. The mounting bracket is as far forward as it can go and I'm not drilling any new holes so now I have to glue or screw an extension onto the plastic tip of the switch.
Flute - 68 MK I Cooper S
Member: VMCI #2474
PostPosted: Fri Oct 09, 2009 5:13 pm
Now with pictures :D
Floor mats in ,
And nice and clean ,
PostPosted: Fri Oct 09, 2009 8:36 pm
NAV-MAN
Did a wheel bearing/ball joint/brake inspection in preparation to my trip to Coffs on the 16th. I found everything in order except a slow leaking right rear wheel cylinder, adjusted the hand brake and it works too good :twisted:
My to do list on NAV:
Replace right rear wheel cylinder,
umm, drive it :D
PostPosted: Fri Oct 09, 2009 9:39 pm
painted the last of the engine (flywheel casing). still waiting on cam to arrive so I can put it all back together.
1965 Morris Mini Deluxe - 998cc SC12
PostPosted: Sat Oct 10, 2009 1:28 am
painted the doors, installed the brake lines, the batt cable etc, and the subframes... busy day... 1/11/09 is getting closer!
PostPosted: Sat Oct 10, 2009 2:36 pm
took the engine out to have a look at... actually mainly so the shell is easier to roll around tbh :lol:
bloody thing is for sale now... don't have the time and patience to get it running, got too much crap happening. Shame as the body really is in excellent condition :(
hooking it up:
success!
PostPosted: Sat Oct 10, 2009 4:06 pm
On the quiet , Ive been the recipient of the 1275LS that was in the for sale section, I finally bit the bullet and jumped.
It arrived friday night on a flatbed organised cap/rotor/points/condensor/plugs (leads looked quite new), oil filter and a few litres of oil.
Sofar today ive dropped it over to get the wheel alignment checked, changed the points, condensor, rotor button , cap, Have no idea on points gap so ive just set it wildly, runs alot better than it did, will nail down the gap setting and correct it later.
Dont have a socket big enough for the sump plug and the plugs a bit screwed so i dont want to play around with it with a shifter so it has the old oil it in and the new filter on, looks like it gets pushed in tonight to its cuby in the shed.
Cant see a timing mark so i gather im going to have to set it via the flywheel.
Will be hunting original 1275LS bits now as i wish to restore it as much as possible.
Have yet to check grease points, it had a lucus distributor cap so i gather its not been changed in a while and it needed it badly.
PostPosted: Sat Oct 10, 2009 4:38 pm
Fitted and wired in a backup thermo fan. Just to give me that extra confidence that I won't overheat my Mini whilst enjoying the parking lots Sydney calls highways on my way to and from work.
1971 Mini K
PostPosted: Sat Oct 10, 2009 5:21 pm
NAV-MAN
I snapped my gear stick :evil:
thankfully matt read had one laying around :wink:
Dave (sitnlow62) also offered me one. Champion blokes the pair of them.
PostPosted: Sat Oct 10, 2009 6:01 pm
Checked that the original pot joint inards fit the new pot joints on the box - they do so all's good.
My order from 'Bob-the-Welder' arrived yesterday but only found it today :roll: so can get stuck into the 'A' panel again.
Thinking of buying some more bits and pieces from the UK while the $ is sooo good. ($50 about $87 at the moment 8) )
David L
PostPosted: Sat Oct 10, 2009 6:04 pm
This space for rent
Nuthin' yet, think I might go and drive it though.. it's such a beautiful evening 8)
Users browsing this forum: No registered users and 403 guests
