It is currently Sat Jul 19, 2025 10:14 am
Post new topic Reply to topic  [ 34 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Sun Oct 25, 2009 1:52 pm
I think that lightening rods and wedging/blading cranks are a waste of time for road engines. For race engines, lightening rods only make sense if: 1) you can't afford aftermarket rods(which are much lighter than lightened rods) 2) you have too much time on your hands 3) you want to take a chance on leaving a stress riser that results in a broken engine(this happens more often than you think).
My aftermarket race rods weigh only 439 grams(with special nutless ARP bolts) and I get them at a price( I can't quote here )but they cost little more than lightened rods prepared by a professional. These are used in a race-only engine along with light pistons, flywheel, backplate and crank. I think that a light flywheel(and maybe backplate??) are the only parts that are worth using for road use.
I know of a friend whose race engine destroyed itself when a rod failed after it was lightened by someone with decades of building race engines. Lost were: Paul Ivey crank, Kent cam, 2 pistons, block, gearbox case. A
chain(or engine) is only as strong as its weakest link.
PostPosted: Sun Oct 25, 2009 2:03 pm
Wedging the crank is worth it on 1275 road engines. Look at the centre main of a 1275 after a lot of miles, they always wear most on the crankpin side of the journal.
This is because Mr BMC never put decent sized counterweights on them.
Wedging the crank removes weight from the crankpin side of the webs, which has the same effect (but lightens the crank too). This is called increasing the balance factor.
I don't believe blading is worth 2 bob on a road motor, as it undoes 1/2 the benefit of wedging by removing metal from the counterweights.
So, you are then back where you started, albeit with a lighter crank. :lol:
PostPosted: Wed Nov 04, 2009 8:20 pm
Mods rock!
While on the subject of after-market Rods, we all know that we can get them from the UK, but did you know that there are at least 2 brands from the US and 1 from here in Oz.......All from what I'm told very very good.
Just thought I'd put it out there.....................
PostPosted: Wed Nov 04, 2009 8:54 pm
Also 1 or 2 good ones from UnZud. :o
PostPosted: Thu Nov 05, 2009 7:50 pm
Any chance your going to share?
As far as I know where allowed to say good things about companies...
The 850 Man
PostPosted: Thu Nov 05, 2009 9:15 pm
Carrillo rods come from US.
http://www.carrilloind.com/
The Oz made one is Argo.
http://www.argorace.com.au/index.cfm?menukey=12
PostPosted: Tue Nov 10, 2009 4:09 pm
I should be running a set of Argo rods in the next few months if all goes to plan. They do custom lengths too which may be handy.
PostPosted: Wed Nov 11, 2009 3:47 am
Longer con rods to increase capacity - is that feasible? What's involved - is it as "easy" as just fitting the rods. I guess the top of the pistons would need to be machined to make sure they didn't go above the top of the block
PostPosted: Wed Nov 11, 2009 9:18 am
Longer rods don't increase capacity, they just move the piston higher in the block (reducing the angle the rods have to work at is a good thing).
PostPosted: Wed Nov 11, 2009 3:25 pm
69elf, there are only 2 ways to increase displacement. Bore it, stroke it, or both. :P
PostPosted: Fri Dec 04, 2009 5:00 pm
Mods rock!
Did someone say CONRODS?
[img][img]http://img121.imageshack.us/img121/1328/conrod01.jpg[/img]
By gtmowog, shot with E990[/img]
PostPosted: Fri Dec 04, 2009 6:09 pm
Pfft... I machined bigger loco ones than that at NSW Railways.. (they were steam then, bro')... :P
PostPosted: Fri Dec 04, 2009 6:51 pm
Mods rock!
These are a little more modern than that!! These are out of one of our Manly Ferries. (Diahatsu 300 mm bore x 350 mm stroke straight 8 with a turbo charger the size of a large dog house)
Here's a piston that goes with it;-
[img][img]http://img266.imageshack.us/img266/4720/piston01.jpg[/img]
PostPosted: Fri Dec 04, 2009 11:22 pm
Oh look,,, REALLY REALLY BIG 4-bolt 850 race rods,,, longer too,,, Hmmm maybe we could ....... Nah,,, wasn`t even funny was it?
i`ll just shut up & go to bed then :-(
PostPosted: Fri Dec 04, 2009 11:35 pm
Diahatsu marine engine, just a copy of a Rolls Royce marine engine, but with japanese reliability not pommy :)
What turbo's are they running BBC [brown bovari] or napier
www.minisprintgt.com
