It is currently Sat Jul 12, 2025 9:44 am
Post new topic Reply to topic  [ 29 posts ]  Go to page 1, 2  Next
PostPosted: Thu Nov 19, 2009 7:03 pm
How ? I am a beginner !
PostPosted: Thu Nov 19, 2009 7:06 pm
Step 1: Fill the tank with unleaded.
Step 2: Drive it.
PostPosted: Thu Nov 19, 2009 7:07 pm
Is it just as easy to convert it back to leaded? :lol:
mooo, I'm a pig!
PostPosted: Thu Nov 19, 2009 7:09 pm
Unfortunately no. You have not been able to buy leaded petrol for over 10 years.
PostPosted: Thu Nov 19, 2009 7:17 pm
Step 2: Drive it.
dont forget the valve saver fluid ,or your car may explode at speeds above 25
PostPosted: Thu Nov 19, 2009 7:19 pm
Step 2: Drive it.
Yeah that'll work, for a while..
then:
Step 3: Rebuild the head with unleaded seats once the valves have sunk into the head, or burned out.
850 exhaust valves were not made from the greatest material. :wink:
PostPosted: Thu Nov 19, 2009 7:24 pm
What are the symptoms of a leaded head experiencing valve seat recession? I have NFI what my engine is but I've been running it on unleaded... :?
Copper 4 lyfe!
PostPosted: Thu Nov 19, 2009 7:25 pm
Step 2: Drive it.
then:
It has worked for my Morris 1100 for the past 7 years. Drive it everyday too.
PostPosted: Thu Nov 19, 2009 7:28 pm
The exhaust valve clearances close up, so the valves eventually don't shut all the way, soon followed by a burnt exhaust valve.
So check your valve clearances regularly to see if the exhaust valves are closing up.
PostPosted: Thu Nov 19, 2009 7:30 pm
[/quote]
It has worked for my Morris 1100 for the past 7 years. Drive it everyday too.[/quote]
do you use the valve saver fluid :?:
Step 2: Drive it.
then:
Aha yes but the head hasn't been rebuilt in the last 10 years, has it!!
I got valve seat recession in a 1098 head in 6 months from rebuild. All it took was use no additive and let my 18 year old son drive it as usual.
Note I did this on purpose, to see with my own 2 peepers what happens. 8)
The hot valves pulled bits of iron out of the head...
My 1360 gets Flashlube additive, it works for me. As it did for all those old iron-headed Holden taxis on LPG years ago.
Last edited by drmini in aust on Thu Nov 19, 2009 7:35 pm, edited 1 time in total.
PostPosted: Thu Nov 19, 2009 7:35 pm
so tomar looks like you can just add the lube when filling or rebuild your head (your cylender head not your other head ) :idea:
PostPosted: Thu Nov 19, 2009 7:38 pm
so you are saying I need my head looked at!
PostPosted: Thu Nov 19, 2009 7:44 pm
Get the head looked at (eventually)
All you need to do is get hardened valve seats fitted.
PostPosted: Thu Nov 19, 2009 7:49 pm
Yep... and stainless valves (or nimonic)
